Sigurd's Avatar
S2 sensor
I have just installed a '91 S2 engine in my '87S. On the new engine there is a sensor, with two electrical connectors, on the underside of the intake manifold. Does anyone know what it is for and how it is connected?
Sigurd
73.5T 3.2SS EFI
X87 944S 3.0
Old 11-05-2008, 03:40 AM
GostRidr's Avatar
Hi Sigurd,
Can you send a pic or narrow it down for me. Is it attached to the intake manifold or just underneath? I don't see anything different than the S, temp sensor, two knock sensors and the idle control valve, but it may be out of my sight. If it helps, I have both the cars you are talking about 87S and 91S2.
Good luck!
peter
1991 944S2 Cab, Crystal Silver Metallic "Platinum Banshee"
1987 944S Alpine White, Ice Shark Lights "Desert Ghost"
2015 Charger R/T Road & Track
Old 11-06-2008, 10:58 AM
Sigurd's Avatar
Thanks. I'll be on it on Sunday.
I must say, there is a definite improvement in torque with the newer engine.
Sigurd
73.5T 3.2SS EFI
X87 944S 3.0
Old 11-06-2008, 01:03 PM
GostRidr's Avatar
Cool! Didn't realize that it was up and running. The sensor can't be THAT important then right?! You will LOVE the 3.0! It is a blast!
peter
Old 11-08-2008, 09:56 AM
Sigurd's Avatar
I'm sorry but I was not able to take a picture. However, I found the sensor on the PET, (944 606 137 00) where it is called "temperature switch for intake manifold". In the wiring diagram there is a sensor called "switch intake pipe cooling" Could it be the same?
Sigurd
73.5T 3.2SS EFI
X87 944S 3.0
Old 11-10-2008, 03:25 AM
