Engine Noise
After replacing the OIL pressure valve i Still have the loud knocking noise....anyone have any idea?? I WILL TAKE A VIDEO TO SHOW YOU GUYS...http://www.youtube.com/watch?v=aYJNgiAFFsg
Old 11-07-2008, 05:46 PM
earlr85944's Avatar
do you have metal shavings in the oil?
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 11-08-2008, 05:35 AM
The noise stops...let me explain when u start it over night it starts to knock then when it warms up you turn it off and wait about 5 min and start it again and the car will be fine..untill next day..
Old 11-08-2008, 09:26 AM
here is what it sounds like when its cold...http://www.youtube.com/watch?v=aYJNgiAFFsg
Old 11-08-2008, 10:37 AM
come on someone must have had this problem
Old 11-09-2008, 09:16 AM
Arizona_928's Avatar
sorry for being a little brute, but does it?
dolor et pavor
Copyright
Old 11-09-2008, 12:25 PM
You replaced the pressrue valve, what was the pressure b4 and after?
You may have crap floating around the oil passages. Put a strong magnet on the pan near the drain and run it for a day then just before draining the oil remove the magnet and if there is metal you should see some in the waste oil.
If no metal try flushing the engine to clean the passages.
Rick
93 968 (My summer car),
05 Cayenne S (My winter car),
79 924 (Wife's summer car), 02 C230k (Wife's winter car),
Old 11-09-2008, 01:04 PM
same pressure...ok maybe i created this problem and i did think of it and changed the oil 2 times...i did some drilling and a little of it spread accross the engine very little..i got most...but some could be left in there..BUT i change the oil 2 time to clean everything out..and it was not making this noise in the begining..then few days later it just started when one of my famly members drove the car...i guess ill flush the engine and you want me to put a magnet attach it next to the drain bolt?
Old 11-09-2008, 02:11 PM
Yeah, it will collect any metal bits that pass by it then when you remove it (just before pulling the plug) the pile of crap will run out with the oil.
Rick
Old 11-09-2008, 03:36 PM
maybe that dumb guy that did my clutch put in wrong oil..
Old 11-09-2008, 06:24 PM
there is some medal stuff....what dose this mean??
Old 11-12-2008, 03:14 PM
Non Compos Mentis
Your oil pan drain plug has a magnet. A little bit of sludge on it is normal, but if it has a bunch of metal shavings on it, your bearings are probably breathing their last.
You're better off not running the car until you at least change the bearings. Once the shavings spread throughout the engine, you're looking at a complete teardown, and most likely a destroyed crank.
My race car had a barely audible knock after coming off the track a few years ago. Pulled the drain plug, and it looked like Don King's hair. I got lucky- I still had oil pressure. Not much farther, and the engine would have destroyed itself.
Old 11-12-2008, 03:55 PM
its very little of it...how hard is this to change? Why dose the knocking stop?
this is what i am going to need?
http://cgi.ebay.com/ebaymotors/83-91-porsche-968-924-S-944-S-S2-ROD-BEARING-SET-NEW_W0QQcmdZViewItemQQcategoryZ33619QQihZ015QQitem Z250308891532QQrdZ1QQsspagenameZWDVW
i also just flushed the engine..
damn another thing to replace..
Old 11-12-2008, 04:02 PM
could it be the oil..the guy might of put in 5w30 but it takes 10w30..
Old 11-12-2008, 04:48 PM
TibetanT's Avatar
5W30 should not be a problem especially this time of year. I run 15W50 Mobil1 during the late Spring and Summer months, then change over to 5W30 Mobil 1 during the Winter months. I always use Mobil1 Syn oil.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 11-12-2008, 07:03 PM
Zero10's Avatar
Send a message via ICQ to Zero10
Sounds like lifters to me. Doesn't sound like rod knock.
There seems to be quite a language barrier here so really I am not certain on a number of things, metal shavings across the engine when drilling?... Metal shavings on the outside of the engine are very unlikely to hurt anything. If you were drilling INSIDE the engine though, then we would need more information.
What is the oil pressure when this is happening? Using a long screwdriver or a stethescope, check if the noise is coming from the top or bottom end.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 11-12-2008, 10:36 PM
i drilled the middle screw on the valve cover cuz it was striped..the pressure is high because the engine did not warm up yet..even when the pressure is normal it still makes the noise unless you restart the car..
Old 11-13-2008, 04:14 AM
i did break a drill bit and i never found it.. could it be that it went somewhere in the engine? lets say something falls in one of those holes under the valve cover..where is it going? the oil pan? i am so confused....
Old 11-13-2008, 04:34 AM
Back from Beyond
"There seems to be quite a language barrier here..."
Slam gets coffee and donut...
"Middle screw on valve cover" doesn't quite do it for me. Was a cam tower hex bolt stripped inside the tower? If it was and you broke a drill bit INSIDE the cam tower you shouldn't have even attempted to crank the motor until you'd rectified that issue. You may have been lucky - the oil return holes in the head may have let the broken bit fall through into the oil pan (shudders).
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 11-13-2008, 11:46 AM
Back from Beyond
Just heard your video. Sounds like lifters. If they don't pressure up and quiet down within about 15 minutes of fresh startup (which can be the longest 15 minutes of your life) then you've got an oil pressure issue - they're a symptom at that point.
Another thing that can make a similar racket is the ignition rotor becoming loose on its shaft and beating the inside of the cap.
HTH and good luck!
All others GONE!
Old 11-13-2008, 11:50 AM
