A few dumb reassembly questions-engine into car
I'm putting an '86 engine and bellhousing into an '82 Euro.
Was there a ground strap from the engine to the chassis? I have one in my pile o' parts but not sure where it came from.
What is the 13mm bolt on top of the bellhousing for? It is right behind the 10mm bolt that holds a few ground wires on the block.
Art
'75 911 US Carrera #390
'74 MGB, AH 3000 BN7 V8,
'65 Mustang Fastback, 66 bronco U13
Old 01-08-2009, 04:21 PM
meister member
speedracing944's Avatar
There should be a ground strap which goes from the center of the fire wall to around the area where the connector for the speed/reference sensors are located.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 01-08-2009, 04:58 PM
Sounds like that's what the 13mm bolt is for, thanks.
Art
Old 01-08-2009, 05:11 PM
