My 84 NA ran a bit hot (I'm in Florida) - replaced radiator...installed low temp sensor and thermostat plus ALL fan related & A/C relays...recharged & bled... NOW it doesn't get to the first bar on the temp gauge.
carlos
blueboydigital@gmail.com
red 84 944 normally aspirated w/ black interior
Old 03-13-2009, 05:00 PM
Proprietoristicly Refined
John_AZ's Avatar
Originally Posted by matthewb View Post
Checking for antifreeze floating on top of your oil will be a waste of your time... you should look for the antifreeze under your oil because water is more dense than oil.
just a suggestion.
Thanks, my mistake.
John_AZ
Old 03-13-2009, 05:20 PM
Red face Oil and coolant leaks
The giveaway to the coolant loss is the brief white smoke when starting the engine. You obviously have coolant leaking into a cylinder which is escaping with the exhaust. I have seen this and it was fixed with a new head gasket. If you are losing that much coolant you are also getting air in the systemcausing overheating.
I just live with the mess caused by the minor oil leaks.
Old 03-13-2009, 09:05 PM
1984 porsche 944 na
ballysdad's Avatar
That's because your car is a bad ass car.....
Old 03-13-2009, 10:53 PM
