-   -   The Random 944 Picture Thread (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/473329-random-944-picture-thread.html)
J1NX3D 08-20-2012 09:29 PM
Originally Posted by CHICKS (Post 6913529)
^that is one of my all time favourite 924's
http://iforce.co.nz/i/1qxj4xx1.onx.jpg
Diceman 08-20-2012 09:37 PM
Originally Posted by Gawernator (Post 6925186)
Belt whine when starting the car? There should be none. And that idle is crazy high. Should be 900 + or - 50.
That "whine" is constant - not just at startup. And the idle is crazy high - hoping to address it here soon.
Gawernator 08-20-2012 09:47 PM
I JUST did the idle adjustment on my car today actually. It's simple and should take about ten minutes (unless your car was already fully warmed up from driving). Personally I've never experienced belt whine unless it was cold and the belts were not tightened enough.
Diceman 08-20-2012 09:49 PM
Haynes manual said I need "special tools" to do an idle adjustment, and that I needed to have it done by a dealer? Do you think it is more likely an adjustment, or vacuum leak?
Gawernator 08-20-2012 09:58 PM
Could be both. I have a small vacuum leak at the moment but my idle is pretty stable. After adjusting my idle myself to the correct specifications the idle is at least twice as smooth. I use the Haynes manual too as a reference but you'll find the most informative are Porsche's shop manuals and a website called Clark's Garage Home Page . Look under I and you'll see how easy it is to adjust the idle. You just have to use a wire jumper to connect two terminals (takes about 10 seconds) and start up the car. You'll use a flat head screwdriver to twist the adjustment screw clockwise until you get to about 950 RPM. Do this with the A/C fan off and the A/C off. Then just unjump the plug, put the cap back on, and start the car. Should run better. If there's still problems it could be vacuum leaks or the AFM (air flow meter). Maybe something else even, I'm still pretty novice myself.
Diceman 08-21-2012 06:26 AM
Thanks much - I appreciate the help.
pauleye 08-22-2012 06:09 PM
my first 944!
http://forums.pelicanparts.com/uploa...1345687700.jpg
XJOSHX 08-22-2012 07:59 PM
http://sphotos-a.xx.fbcdn.net/hphoto...35956989_n.jpg Random picture from today
Racerbvd 09-15-2012 01:22 PM
http://forums.pelicanparts.com/uploa...1347744067.jpg
http://forums.pelicanparts.com/uploa...1347744083.jpg
http://forums.pelicanparts.com/uploa...1347744107.jpg
http://forums.pelicanparts.com/uploa...1347744130.jpg
http://forums.pelicanparts.com/uploa...1347744155.jpg
james6speed 09-17-2012 11:17 AM
Sun was hitting it, so took some shots.
http://i1091.photobucket.com/albums/...0Pics/wash.jpg
http://i1091.photobucket.com/albums/...Pics/wash2.jpg
http://i1091.photobucket.com/albums/...Pics/wash1.jpg
http://i1091.photobucket.com/albums/...Pics/wash3.jpg
JAXTURBO 09-19-2012 04:26 PM
... that is some badass looking pipe you got there
Racerbvd 10-16-2012 05:09 PM
http://forums.pelicanparts.com/uploa...1350427407.jpg
http://forums.pelicanparts.com/uploa...1350427446.jpg
http://forums.pelicanparts.com/uploa...1350427482.jpg
http://forums.pelicanparts.com/uploa...1350427515.jpg
http://forums.pelicanparts.com/uploa...1350427553.jpg
http://forums.pelicanparts.com/uploa...1350427584.jpg
http://forums.pelicanparts.com/uploa...1350427616.jpg
http://forums.pelicanparts.com/uploa...1350427640.jpg
ernie9944 10-16-2012 05:25 PM
^^Byron is that a an Amzone Pearl Green & what year is it,if possible more infos & pics of the interior & engine bay.TIAhttp://forums.pelicanparts.com/suppo...s/beerchug.gif
Racerbvd 10-16-2012 05:51 PM
A 93, will be doing more pictures tomorrow, not much of an int. as it was tracked, and will continue to be:D..
diamondzz 10-16-2012 06:40 PM
http://forums.pelicanparts.com/uploa...1350441424.jpg
http://forums.pelicanparts.com/uploa...1350441513.jpg
http://forums.pelicanparts.com/uploa...1350441570.jpg
Racerbvd 10-17-2012 06:27 PM
http://forums.pelicanparts.com/uploa...1350527213.jpg
EliteThink 10-17-2012 07:54 PM
http://forums.pelicanparts.com/uploa...1350532459.jpg
Tom944 10-18-2012 05:37 AM
http://i1166.photobucket.com/albums/...ps2297a903.jpg
EliteThink 10-18-2012 06:53 AM
Time for some aftermarket wheels...:-)
Tom944 10-18-2012 09:02 AM
Good idea. Hatch need aligning too.
Here's the real one!
http://i1166.photobucket.com/albums/...4/65025ac1.jpg
Tom944 10-18-2012 09:04 AM
Damn difficult to find a toy one in Maraschino Red!
james6speed 10-23-2012 04:13 AM
http://i1091.photobucket.com/albums/...ps103b579e.jpg
EliteThink 10-23-2012 05:29 AM
Awesome pic. did someone climb a tree to take it? :-)
james6speed 10-23-2012 06:14 AM
not sure, but all of those cars are owned by one guy. He has a couple more not pictured from what I understand. Picture was posted on Craigslist for a car for sale ad.
FransB85 10-23-2012 09:45 AM
Nice little weekend in the countryside with my friend in his TR6
http://forums.pelicanparts.com/image...0938/28742.jpg
Gawernator 10-23-2012 09:50 AM
Gorgeous
Ederd 10-24-2012 08:14 PM
His house wraps around and its from a second story window. I thought it was some tree climbing awesomeness as well until he clarified.
Racerbvd 10-25-2012 08:47 AM
http://forums.pelicanparts.com/uploa...1351183589.jpg
http://forums.pelicanparts.com/uploa...1351183623.jpg
http://forums.pelicanparts.com/uploa...1351183651.jpg
Gawernator 10-25-2012 01:50 PM
http://forums.pelicanparts.com/uploa...1351201801.jpg
CHICKS 10-25-2012 03:03 PM
Your car looks great Gaw.
Gawernator 10-25-2012 03:57 PM
Thanks, it's all I have to my name lol
Horrido 10-25-2012 04:06 PM
Lothar
http://forums.pelicanparts.com/uploa...1351209933.jpg
thekidd 10-25-2012 04:17 PM
Gawernator, is you car parked at the PHilly sports complex?
http://i1181.photobucket.com/albums/...894B68DB43.jpg
Gawernator 10-25-2012 04:23 PM
No, local College parking lot.
thekidd 10-25-2012 05:09 PM
Ah ok. The roofing looked like the complex lot. Let me know if y'all (Central Jersey crew) need help or go for a run. I'm in bucks county PA. About 1.25 hrs from point pleasant NJ
Gawernator 10-25-2012 05:32 PM
Yeah, the campus has a covered parking area I always go to. They are solar panels and it's supposed to be "green". I couldn't give a **** but it provides shade to protect my 944! Green to me is nuclear power. Hooyah
Hellraiser 10-26-2012 01:31 AM
(Nearly) Finished :)
http://img.photobucket.com/albums/v4...70715530_n.jpg
http://img.photobucket.com/albums/v4...S/DSCN0749.jpg
http://img.photobucket.com/albums/v4...S/DSCN0751.jpg
http://img.photobucket.com/albums/v4...S/DSCN0753.jpg
Gawernator 10-26-2012 01:44 AM
Awesome dude!!
Hellraiser 10-26-2012 02:28 AM
Thx, so is yours with the repaint and Fuchs :cool:
SpeedyS2 10-26-2012 07:15 AM
That's good stuff!
Random picture...
http://forums.pelicanparts.com/uploa...1351264497.jpg
