Engine Drop - Remove Head First For Extra Clearance?
This sounds so obvious...but I have not seen this mentioned - that to gain some extra clearance for an engine drop I may as well just remove the head first - make sense?
Old 06-03-2009, 05:34 AM
u could, but it's not needed. as long as you the 21 inches clearance, you're fine.
follow
http://www.clarks-garage.com/shop-manual/eng-01.htm
Old 06-03-2009, 06:13 AM
Just remove the distributor cap and rotor and the radiator fans, and you should have plenty of room.
Good luck, George Beuselinck
Old 06-03-2009, 07:44 AM
exitwound's Avatar
I had to remove the oil filter to get another 1/2" to 1" on the right side just to be safe.
-Patrick
Black 1986 944
Old 06-03-2009, 08:28 AM
Schumi's Avatar
If you remove the dist. cap, also remove the rotor. I didn't and when lowering the engine out, I bumped it into the radiator crossmember and it chipped the rotor. They aren't cheap.
M
Old 06-03-2009, 08:48 AM
Politically Incorrect
onZedge's Avatar
I would remove the radiator (you never know) - they aren't cheap either.
Edek
'87 924S
'91 535i
Old 06-03-2009, 04:51 PM
Arizona_928's Avatar
I wouldn't as the studs go up to just about the same height. If you need acouple inches a block of wood works well.
dolor et pavor
Copyright
Old 06-05-2009, 07:15 PM
meister member
speedracing944's Avatar
drop it with the head. Remove radiator as others have suggested.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 06-05-2009, 07:17 PM
