slow944s's Avatar
Setting timing on my 944S
Ok we've got the head replace and almost everything back together. Is there a good write up on setting the timing on the 16V engines? I don't want to mess this up and have to start all over again. Thanks in advance.
84, 944 Silver--Crashed and burned.
87, 944S White--Daily driver
Old 06-10-2009, 07:26 AM
The best description is in the factory service manual.
Keep in mind that that is only to set the initial timing. You will have to iteratively tweak the relationship between the exhaust camshaft and the crankshaft to make the car "come alive".
Good luck, George Beuselinck
Old 06-10-2009, 07:59 AM
slow944s's Avatar
Where can I find that on line???
Old 06-10-2009, 08:39 AM
http://lmgtfy.com/
Old 06-10-2009, 09:40 AM
pontifex4's Avatar
Good question
George, I recognize that you don't suffer fools gladly, but I think this is a pretty good question (and I want to know, too). Can anyone elaborate on the process of fine tuning 16v timing? How much art/skill is there to it? How about warning signs that you're going the wrong way, etc?
Thanks in advance,
Charlie.
Charlie
'99 996 C2 6 speed - Arctic Silver
Old 06-10-2009, 11:49 AM
You set the initial timing according to the book. Put all back together. Take a test drive. Take it apart. Advance the timing a couple of degrees. Take a test drive. Is it better or worse? If it's better, advance the timing a couple of degrees. Take a test drive. Is it better or worse? If it's better, advance the timing a couple of degrees. Take a test drive. Is it better or worse? If it's better, advance the timing a couple of degrees. Take a test drive. Is it better or worse? If it's better, advance the timing a couple of degrees. Take a test drive. Is it better or worse? If it's better, advance the timing a couple of degrees. Take a test drive. Is it better or worse? If it's better, advance the timing a couple of degrees. Take a test drive. Is it better or worse? If it's worse, retard the timing a couple of degrees. Lock it down.
You're done.
(It only took me ten hours the first time.)
Old 06-10-2009, 12:25 PM
pontifex4's Avatar
Ha, okay, fair enough! I guess I'm just a little gun shy of experimentation when it comes to timing.
Thanks for the help,
Charlie.
Charlie
Old 06-10-2009, 12:34 PM
slow944s's Avatar
It's alive! It's alive! It's aliiiiiiiiiiiiivvvveeee
Thanks George and everybody for your help......Jerry
Old 06-10-2009, 05:09 PM
