Strange Gauge Problem
I have a weird gauge problem. Even before the car is started in key pos 2 the temp gauge pegs to full hot, it will stay that way until the car is running for like 15-20 minutes, i hit a hard bump in the road or if I tap on the glass hard. What could it be ????????
87 944 72 914 Sold 84 944 Sold 85.5 944 Sold 78 924 (first car) RIP Last edited by WizPorsche944; 08-09-2009 at 08:18 AM.. |
bad gauge
Good luck, George Beuselinck |
your average wrencher...
pull the cluster apart and clean the contacts on the back side. the little football looking things. the center is power and the 2 outside ones are the grounds. I used 1500 sandpaper and it worked just fine. worth a shot before you condemn your gauge
1982 931 *project* 1986 951 Garrett turbo, Rogue Tuned (sold )1987 944S chipped, konis, rollbar (traded) 1979 924 total rebuild and blueprinted (sold) |
Proprietoristicly Refined
In the Pelican tech center ^^^^above on top of page, There is a good DIY on late guage fix.
http://www.pelicanparts.com/techarticles/944_taillight/944_gauge_problems.htm GL John_AZ 1988 924S + 1987 924S |
