Learn from my mistake
BB. replaced all front stuff in feb,2004. car sat often since then, drove maybe 20-25k miles. This morning, cruising around town, 45 mph. Threw balance belt off (it broke clean across one link) and started vibration. I had to look at pavement to be sure i was not on the rain cuts, or the ones that warn that you are going off the road. That is exactly the sound it made, and it felt like maybe a left front tire too. Anyway, I was lucky!! no interference with other belts! The break was clean across one tooth. Will post pix in the coming days. Plan is to limp around today, and weather shoulbe nice sunday for close inspection of all belts, especially YOU KNOW WHICH ONE!
chance favors the prepared mind 1987 944 n/a 5spd. who remembers dial phones?. 'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE" |
Wow man that sucks! Seems like a long time though for those belts. At least it was the balance shaft belt and not the timing belt, then you'd really have an issue.
I nearly left on another 300 mile trip this weekend, but something said no, maybe sat night or sunday departure instead. I may drive the chevy 1 ton truck for a while till my heart slows down. LOL
meister member
Out of curiosity can you share your tensioning method and procedure? (twist, kriket, P9201, Arnnworks kit)
Did you retension at 1500 miles? Hopefully the repair goes well. Speedy ![]()
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
hand method, retensioned. it whined up until about 3 months ago, then definitely quieted down to a normal level, as compared to my bros car. I did check it just about the time it quieted down and by the hand method, it did feel loose. I was planning on doing the belts soon, just because it had had some periods of up to 4 months sitting, when I was fighting the dreaded sensors..
i have the packages that these belts came in in 2004, with tho old belts in the packages, so I will know brands soon as well as have pix. I am smiling!
Automotive Necromancer
Wyait
You might want to do both belts if you are in there. Just a thought. Glad it was the BB, that makes things a lot easier to deal with. Was the idler spacing set on the second adjuster?
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix. |
Thread Tools | |
Rate This Thread | |
