pinball_0's Avatar
S2 makes whiney Noise after sitting overnight
My 90-944S2 cabrio with 133K miles makes a whiney noise when first set in motion after sitting overnight, sounds like an old truck's gear noise low pitch "zzzzZZZZZ" that goes higher as speed increases and it seems to be coming from near the gear shift area, when I depress the clutch it is quieter and seems related to speed, it does it for about the first 2 miles then is quiet from then on. It can be quiet all day. Let sit overnight and does it again in the morning.
Anyone have any idea what this is??
Old 10-18-2009, 08:47 PM
adrian jaye's Avatar
could be belts,
I had the belts changed, and untill the 1500mile retension it did the same thing
I would get yours belts tension checked
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 10-19-2009, 08:02 AM
your average wrencher...
throw out-bearing?
1982 931 *project*
1986 951 Garrett turbo, Rogue Tuned (sold)
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
Old 10-19-2009, 10:05 AM
Luis de Prat's Avatar
I'd second checking the belt rollers, as it sounds like you have one nearing seizing point. Do you know when they were last replaced?
Old 10-22-2009, 04:21 PM
power steering groan.
clean your reservoir or just replace it with a new one. it's cheap.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 10-22-2009, 04:56 PM
