![]() ![]() ![]() ![]() ![]() And yes i used a camera phone
Jaime O. Thank god I crashed or i would never have owned a porsche 83 944 daily driver (clutch and tt time) 85 325e BMW T-boned R.I.P. |
wow, that looks like a LOT of deposits! I see you are using platinums?
i HAD PLATINUMS WHEN I FIRST DID MINE HEAD IN 2004, RECENTLY CHANGED TO ac REUULAR PLUGS, 65 I THINK. WILL POST PIX AND COMPARE deposits WHEN i PULL MY HEAD OFf for THE LEAKING head gasket, in a couiple weeks i guess. originally, did you have head gasket symptoms, milkshake, or white somke, or compression from the coolant reserviour? mine is plumes of white smoke in exhaust.
chance favors the prepared mind 1987 944 n/a 5spd. who remembers dial phones?. 'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE" |
Garage Helper
Wow what deposits (Burning oil for a long time??) - Did not see any valve marks in/on pistons - how is the head and valves? The back side of the exhaust valves probably look the same as the pistons or worse?
Maybe a good cleaning to all parts associated and a standard rebuild??? That belt could have caused some pretty good damage Merry Christmas and Happy New Year for you and the car
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word Last edited by Cocacolakidd; 12-14-2009 at 11:02 AM.. |
No Milkshake, Just a few Small Oil leaks that were hard to spot, and a few spot were coolant leaked even tho i put all new hoses. #3 spark plug allways had alot of deposit, it seemed oil the rest were ok.
3 out of the 4 exhaust valves hit the pistons if you look in the photos the bottom parts of the vavle have a little shiney metal showing. And it apeared that the oposite side of were the valves got hit that there was a small gap, there is posibly like you said allot of deposites on the other side of the valves but i only just glanced at the old head but other than that it seemed in great shape. Maybe it already had a head job because it had a Turbo head gaskit and the flat part where the head mates to the camshaft had a few numbers stamped on it. what you think? anybody have a clue how much it would be to replace my three bent vavles with extra ones off a third head that I have as a backup for the backup.Idea of how much resurfacing the head would cost if i need it? Last but not least any tips on how to get rid of the deposits on my pistons before i put on the head? Seafoam, Marvel mystrery oil ?
An afternoon of cleaning
Took a while but with some chemicals lots of rags and a cheap set of Non marring gasket remover tools and BOOM!
