Timing belt question
I'm doing my belts. Printed instructions from Clark's Garage. It says to remove the crankshaft bolt then the power steering, alternator, and balance shaft sprocket as one unit. Later it mentions possibly needing a small pry bar for one of the steps, but it makes removing the crank pulley sound like removing the belt covers after undoing all the bolts. Do I need a puller, or a prybar? Or am I just missing something real obvious?
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
Malo periculosam, libertatem quam quietam servitutem.
Old 12-30-2009, 05:51 PM
exitwound's Avatar
This may not answer your question directly, but I've had the crank pulley stick on me to where I had to use a puller. I've also had it come right off too with nothing more than my hands. You need to remove the crank pulley to get the back timing cover off though.
-Patrick
Black 1986 944
Old 12-30-2009, 06:32 PM
TibetanT's Avatar
Hello There:
First, after removing the crankshaft bolt the pulley will come off no problem. Next, there are four (4) 10mm bolts that need to be removed. You will need a gear puller, at least I did, to remove the balance shaft drive gear and then the cam drive gear behind it. Be careful not to loose the key on the crankshaft.
Good luck with that!
Exitwound is correct; you will need to remove these to be able to do the job such as change belts and change out your seals.
Hope this helps.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 12-30-2009, 07:15 PM
earlr85944's Avatar
if doing the belts you dont need to remove the pullies or gears, only if doing the seals
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 12-30-2009, 08:07 PM
Rjackel944's Avatar
thats what i thought... the write up on clarks garage says it's extremely difficult though. I'm getting ready to do my belts also.
1985.1 Porsche 944-Koni Adjustable Rear Shocks
Old 12-30-2009, 08:13 PM
Redline Racer
HondaDustR's Avatar
It's not that hard. You have to be careful when slipping the new cam belt past the small space between the balance belt sprocket and the rear cover, but it can be done. Don't crimp the belt, but it will slide into place through there. Removing the pulleys is a PITA in comparison since you have to also remove the starter and install a flywheel lock.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 12-30-2009, 09:19 PM
earlr85944's Avatar
yup
83 944....bye bye
Old 12-31-2009, 06:27 AM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
sacrilige.
OK, for belts only you can get by without a FW lock if you are careful and you don't need to remove the CS pulley. However.....you got to be careful and take a good look at all the components. There is a good chance an idler or pulley has gone south on you.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 12-31-2009, 08:27 PM
