Toofah King Bad
Tech Bulletin Request
Found 602-01 of PET, under part # 951 351 421 00 (86 951 front caliper):
see technical information GR.4 NR.2/86 TIA, rasta
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Toofah King Bad
Really, nobody has this?
All Spooled Up
The only TSB's that I can find for 2/86 are #18601: engine - drive belt checking and adjusting values; and #18605: engine - low or no oil pressure upon cold start.
Let me add that I checked through ALL of the TSB's for an 86 951, all the way up to 9/05, and, out of the 50 or 60, or so, that I see, there are NONE relating to brakes or calipers. This leads me to believe that what you are looking for is NOT a TSB.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) Last edited by wild man; 01-03-2010 at 12:44 PM.. |
That Tech Information Bulleting pertains to the composition of brake pads for the 86 Turbo.
Good luck, George Beuselinck |
All Spooled Up
What is the 5-digit #? Is it 60201? That # isn't coming up under what I have for an 86 944 turbo.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
All Spooled Up
If what you are looking for is a TIB, I don't have those. I only have TSB's (technical service bulletins). Sorry about that - my mistake.
Toofah King Bad
Thanks for response, wild man. Mistake woujld appear to be mine., George, definitions of TIB and TSB??
TIB is what Porsche calls them on PIWIS, the electronic information system. TSB is the old term for paper distribution.
All Spooled Up
That is funny though, none of the TSB's that I have are on a piece of paper.
Thread Tools | |
Rate This Thread | |
