Toofah King Bad
Rasta Monsta's Avatar
Tech Bulletin Request
Found 602-01 of PET, under part # 951 351 421 00 (86 951 front caliper):
see technical information
GR.4 NR.2/86
TIA,
rasta
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 01-02-2010, 10:22 AM
Toofah King Bad
Really, nobody has this?
Old 01-03-2010, 09:17 AM
All Spooled Up
The only TSB's that I can find for 2/86 are #18601: engine - drive belt checking and adjusting values; and #18605: engine - low or no oil pressure upon cold start.
Let me add that I checked through ALL of the TSB's for an 86 951, all the way up to 9/05, and, out of the 50 or 60, or so, that I see, there are NONE relating to brakes or calipers. This leads me to believe that what you are looking for is NOT a TSB.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 01-03-2010, 01:25 PM
That Tech Information Bulleting pertains to the composition of brake pads for the 86 Turbo.
Good luck, George Beuselinck
Old 01-03-2010, 03:29 PM
All Spooled Up
What is the 5-digit #? Is it 60201? That # isn't coming up under what I have for an 86 944 turbo.
Old 01-03-2010, 06:21 PM
All Spooled Up
If what you are looking for is a TIB, I don't have those. I only have TSB's (technical service bulletins). Sorry about that - my mistake.
Old 01-03-2010, 06:27 PM
Toofah King Bad
Thanks for response, wild man. Mistake woujld appear to be mine., George, definitions of TIB and TSB??
Old 01-03-2010, 10:31 PM
TIB is what Porsche calls them on PIWIS, the electronic information system. TSB is the old term for paper distribution.
Old 01-04-2010, 05:21 AM
All Spooled Up
That is funny though, none of the TSB's that I have are on a piece of paper.
Old 01-04-2010, 12:10 PM
