Poll: Life expectancy of valve stem seals!
Poll Options
What mileage when you had to replace valve seals?
I'm toiling over whether to change valve seals or not as I have the cam tower off.
Engine is a very low mileage unit and burns no oil. 62K miles.
What is a rough estimate of their life expectancy in miles?
Are these seals affected by age the same way as o-rings and other rubber seals? They seem to me to be of a longer lasting material.
1990 944 T: 100 000 km/63K miles,
1997 986 2.5L: 95 000 km/60K miles,
Living in the trackless land of plenty!
Old 01-23-2010, 01:50 AM
so how bad is it burning oil on startup and high engine load?
Old 01-23-2010, 08:13 AM
It does not burn oil on startup or under load - yet.
I'm simply trying to find out how long they can be expected to last on a street car.
Old 01-23-2010, 10:05 AM
Just thinking out loud
mattdavis11's Avatar
Where is the option for over 200K?
91 FJ80
84 Ram Charger (now gone)
Old 01-23-2010, 01:52 PM
good point. Unfortunately I can't change the poll once it's done!
Old 01-23-2010, 02:36 PM
Proprietoristicly Refined
John_AZ's Avatar
I voted 100K because that is when my head gasket went.
The seals may have been OK.
If you decide to install new valve stem seals, there are a couple varieties besides rubber that come in the Victor Reinz HG kit.
Old 01-23-2010, 05:20 PM
Judging by the poll mine should last another 100K at least. However, when I took of the exhaust manifold I discovered a blob of black crud on the bottom of one of the exhaust valve guides. Could this be burnt oil?
Old 01-26-2010, 04:30 AM
Old 01-26-2010, 04:36 AM
All Spooled Up
It could, and most likely is. It would appear that you have a leaker. With such being the case, good time to replace the set. I guess you could just replace the bad one though.
P.S. - I will have what you need when I replace my compressor section with a K27 compressor, tentatively slated for may or june. PM me at that time if still needed.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 01-29-2010, 03:54 PM
Redline Racer
HondaDustR's Avatar
Make sure you get the reddish colored vitton seals rather than the regular black rubber ones. The vitton stays pliable longer.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 01-29-2010, 09:51 PM
The ones I have are grey on the outside and rubber red on the inside. Are those the ones?
Old 01-30-2010, 02:33 AM
Redline Racer
HondaDustR's Avatar
I don't know.
Old 01-30-2010, 11:07 AM
