Adj. FPR Setting: Help
Hello guys, I took out my old 2.5 BAR FPR for an adjustable one with a fuel pressure gage. What should I adjust the fuel pressure regulator to be at idle? 30psi? I don't want to run to lean or to rich. Its on a 1986 Porsche 944 turbo with a full 3" exhaust, Lr boost enhancer, 2 wg shims and a autothority stage 2 chip set. Thanks.
Randy
1988 944 Turbo: Modified Corvette Killer
Old 02-04-2010, 01:54 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
I would go with 36 to 40 and see how it runs - That's where I have mine set and it's runnin' great - My AFR gauge says it is stoic so that's good here.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 02-04-2010, 07:28 PM
Thats what I was thinking, I have it set at 35 and it seems fine, I just dont want to run to lean. I think I will set it up to 38. Thanks for the response.
Old 02-04-2010, 08:20 PM
All Spooled Up
36 would be right on the money. That is at idle with the vac/pressure line disconnected from it and plugged.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 02-05-2010, 03:41 AM
