Adj. FPR Setting: Help
Hello guys, I took out my old 2.5 BAR FPR for an adjustable one with a fuel pressure gage. What should I adjust the fuel pressure regulator to be at idle? 30psi? I don't want to run to lean or to rich. Its on a 1986 Porsche 944 turbo with a full 3" exhaust, Lr boost enhancer, 2 wg shims and a autothority stage 2 chip set. Thanks.
Randy
1988 944 Turbo: Modified Corvette Killer |
Garage Helper
I would go with 36 to 40 and see how it runs - That's where I have mine set and it's runnin' great - My AFR gauge says it is stoic so that's good here.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word Last edited by Cocacolakidd; 02-04-2010 at 08:17 PM.. Reason: sp |
Thats what I was thinking, I have it set at 35 and it seems fine, I just dont want to run to lean. I think I will set it up to 38. Thanks for the response.
All Spooled Up
36 would be right on the money. That is at idle with the vac/pressure line disconnected from it and plugged.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
