TSNAPCRACKLEPOP's Avatar
i do not know what it is, or how to tell if it is set correctly.
At this point , I would replace it with something that I do know what it is, and I would set it to the specifications with which I am familiar.
then, i would drive the truck.
i wish you good luck, mine has one or two of those.
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 02-25-2010, 07:44 PM
drift a 944's Avatar
I removed mine. No emissions testing in FL either. And WOW that price is absurd!!! Good thing I still have it in a junkpile somewhere, it might be worth a few bucks!
- Elliott Grafton - 944Barn
Old 02-25-2010, 09:09 PM
All Spooled Up
The camera was in fact, too close to get a decent focus on it. I understand it is for the vapor can(ister) purge cycle. I have no plans to remove it from either car, but I think I did mess with the one on the 924S, years ago. You can tell by the fact that the paint (or what ever it is) spot on the threads is several turns above the body of the unit. That's why I was asking about how to check if it is properly adjusted. Since it appears that it is something that is set once, and not supposed to be messed with after that, I'll just let it go. Or maybe I'll crank it back in the couple of turns that it looks like it was cranked out.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 02-26-2010, 11:53 AM
Avatar's are to SMALL.
Send a message via Skype™ to cvriv.charles
Originally Posted by Rasta Monsta View Post
Can't quite tell from that picture. Can you provide a close-up?
That was funny. But what was even funnier,...
That's about close as the camera that I am currently using can focus to it (it was like, 2-3 inches away). It is, in fact, directly in front of the diagnostic port. Although the actual picture is from my 87 924S, my 89 951S has the exact same thing.
I spit oatmeal all over my laptop while reading,... damn.
1986 951 - Wrecked. Being used for engine swap and parts.
1987 944 - SCCA specification track/ street car. Awaiting 951 engine and parts.
Old 02-27-2010, 05:50 PM
All Spooled Up
I know, it's funny, but I wasn't sure what the rasta masta meant about getting a close-up. The reason I was so close, was so that I didn't have to add an arrow pointing to the part that I was referring to.
Old 03-01-2010, 07:11 AM
Only in good fun fun wildman. I've done some even funnier stuff in the past,...
Old 03-01-2010, 09:20 AM
