Bad A/C Compressor Switch
I am trying to get the a/c in my '87 944 working again but have a bad dash compressor switch. I've heard that there are certain climate control units that have removable switches. Pelican sells these replacement switches for late model 944's. My question is, do all of the late model boards have removable switches? Also, the switches sell for about $100... Ugh. Is there anyway to bypass the button and use some kind of aftermarket switch for the A/C? Thanks in advance!
'87 944 |
All the ones I have seen the switches are soldered in. With that said I have a controller with bad electronics but good switches if you wanted to replace yours yourself I'd sell it for $20
87 944 - Daily Driver - Son took it and now brought it back |
Garage Helper
Hello,
Hope this is proper - trying to help. I have a complete control unit you could have. Used but all worked perfect before pulling it out - $50.00 + 10.00 ship. It looks very nice also. (I was going to keep it in case my normal control unit went out, but I can always get another- I paid 50 for it so that keeps it even). Ed. nushi@q.com <---------- email is better for me.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word |
Desertt5
Whne I bought my 944S, the PO said the switch was bad and had a new one ready to go in. Mine was soldered, but I found out it was the relay that was actually bad.
Semper Fi |
Feelin' Solexy
How do you know the switch is bad? e.g. have you used your meter on it, or are you assuming that the compressor not kicking in = bad switch? Keep in mind that the system is designed to cut out if there is not sufficient pressure...
Grant In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 2011 Pursuit 315 OS, 2022 Tesla Y Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S |
I suppose if i were able to find a new button cap (The part with the snowflake on it) the switch itself would work fine. I'd be surprised if i could find just that part. Quote:
Thanks for the help!
'87 944 |
Desertt5
Hey, just saw you were in ABQ. I should still have the new one I got from the PO. PM me your number. I live way out near Vetanna Ranch if you want it and I can find it.
Semper Fi |
