Directionals not returning
On a '88 944 my directionals don't turn off after a turn. I also noticed with the key off and out of the ignition if the directional is left either up or down the directional light outside the car is on. Is this on all cars or is something broken on mine. I just got this car but I also noticed it on a '83 I had years ago.
Signals should cancel - they have little plastic tabs that break and fairly commonly.
You should look for a new turn signal/washer switch assembly. If you leave the switch left or right - yes it leaves that indicator on. I think it is designed so if you park on a dark street the one side of your car is visible.
Brad Tompkins Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968 |
Toofah King Bad
Single sided parking lights are a feature. If you park on the road, turn on street-side lights.
No cancel = busted stalk. $$$
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Then again you may just need to remove the steering wheel and wrap a bit of duct tape (I used Gorilla tape) around the small plastic tab projecting from the wheel near the brass horn contact ring.
All Spooled Up
You probably need new ones.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
I did the fix for this.
Keep searching searching the topic, you'll find it.
turn signal does not click off by itself. - Rennlist Discussion Forums |
Turn Signal Switch Not Cancelling After Turn
Fairly new to the 944/951 world and reviving an old thread...
I've seen posts about wrapping the steering wheel cancelling tab with electrical tape to effect repair of a non-cancelling turn signal switch (assuming parts not broken). I attempted to attach a piece of heat shrink tubing to the switch tab itself only to have it fall off during the initial testing. The interesting thing is that the initial heat from the heat gun almost totally resolved the issue: a little more heat and it seems to be functioning normally. Out of more than 100 uses thus far, the turn signal has only failed to return once and that happened around the 7th use on an 'iffy' turn (may not have even engaged return tab). It has now been over a month and the problem has not recurred. My best guess is that the heat displaced some hardened grease allowing softer grease to flow into pivot points. ...every blind squirrel finds a nut sooner or later! Peter |
WD40 works great at rejuvenating old grease.
Red 84 w/25,xxx miles Stone Gray 89 S2 w/90,xxx miles |
