SpidrVII's Avatar
Installing Engine - Lost In Wires!!!
Helllo Folks,
I am installing my engine after a very long time of having it out (approx 9 months) and I can't remember where all these wires connect.
Does anybody have pictures or diagrams of where these many wires, harnesses, and hoses go?
Would somebody post several pictures of their 944's engine bay? A close up between the rear of the engine and firewall would be very helpful.
I tried to find the only other guy in town with a 944, but he cannot be located.
Thanks,
Mike
1983 Porsche 944
p.s. For those who are going to pull your engine, get the removal on video!!!
1983 Porsche 944
Old 04-16-2010, 11:18 AM
VII VII is offline
unless you're in a very small town, it is likely there are other 944's floating around. A wiring diagram would be your best bet. The repair manual would be helpful for about $15 or so at your local auto parts store though I'm sure you could just print one from the internet.
I recently bought two Midgets with all the wiring taken apart so I know I will have similar issues. I've been collecting as many pictures as I can of the engine bay and those I can find of various wire routes. I have a restoration manual, a hanes manual, and two versions of factory repair manuals besides the moss motorsports manual with lots of diagrams. Hit that google button and see what you find.
Old 04-16-2010, 11:58 AM
yea there's def a bunch of wires...4 fuel injector clips, 2 alternator hookups, 3 start hookups, engine coolant temp sensor, oil pressure sender, ever important speed/ref sensors, then engine ground in the back....and im' sure there's others i haven't remembered
Old 04-16-2010, 12:16 PM
Architect / Car Guy
carlege's Avatar
Send a message via AIM to carlege
wiring diagram would be your best bet but they can be confusing
Looking Forward to getting my First "car" Porsche 951
Old 04-16-2010, 12:50 PM
I have a whole second engine in my garage on the stand that someone cut out...very handy in referring to while I rebuild #1. Take a picture of your wire ends and I will take a closeup of where they go.
1983 944 - project mode
2002 Ford F150 - every other daily driver
1976 Honda Goldwing - the other days
Old 04-16-2010, 03:20 PM
VII +1 for old jap bikes!
Old 04-16-2010, 03:22 PM
SpidrVII's Avatar
Where do the two grounds mount? Where does the starter motor wire (there's a butt splice on mine) connect? Since mine is broken, can I replace it with a straight wire or do I need to get a new connector?
Where does one mount the wiring harness?
Thanks a million!!!
1983 Porsche 944
Old 04-16-2010, 04:22 PM
starter has 3 wires going to it. the 2 smaller wires are on the same terminal IIRC.
those two grounds go on either side of the black grounding block where your big grounding wire is already connected
Old 04-16-2010, 04:34 PM
VII VII is offline
Doing my best to keep (semi) old school alive. Glad to find another fan amongst the crowd.
I will literally be doing the same thing of posting a pic of connections/wires and asking where they go in the MG forums. Those wiring digrams become a blur after 30 min of trying to trace. Bleh, best of luck.
Old 04-16-2010, 05:53 PM
Yeah the wiring diagram in Haynes is pretty bad...looks like a photocopy of a napkin.
Will get those pictures in the morning when it is light out.
Old 04-16-2010, 06:20 PM
Here is where the ground wire goes. You don't want to see my harness or starter connection, a lot of undoing to be done there. I love previous owners that know just enough to make a mess.
Old 04-17-2010, 10:55 AM
SpidrVII's Avatar
Ahh...so now I know where to mount that and the wiring harness. The piece that you have your thumb on is the starter connector that I need to replace. One: Where does that wire connect and Two: Since mine is broken, can I replace it with a straight wire or do I have to have the piece replaced? (see previous picture showing my broken part).
Also, I am at a loss of exactly where the vacuum lines connect. If someone could post pics of those, I would be most grateful.
Thanks!!!
1983 Porsche 944
Old 04-18-2010, 11:26 AM
I'm right behind you lol. Got to this point about an hour ago. Going to replace all the vacuum hoses, prob on Wed night. I'll let you know what I find between now and then if no one else responds.
Old 04-18-2010, 01:52 PM
1984 vacuum lines
Old 04-18-2010, 03:33 PM
And this. It says 1985.5+ but I can't find one for our cars. It looks pretty close to our early models, so hopefully if there is a difference someone will chime in.
Fuel and Vacuum Line Diagram (1985.5 and Newer N/A 944s)
Old 04-18-2010, 03:41 PM
SpidrVII's Avatar
WOW! That's so cool of you to respond and with all this useful info.
Thanks!!!
1983 Porsche 944
Old 04-18-2010, 09:49 PM
i have a 83 myself i just transplanted a 87motor into, looks like your on a roll if you find something that doesnt add up ill help where i can to . those 2 ground wires you have pointed out in the picture attach to the rear end of the block if you hadnt found that already.
1983 944 Guards Red (87' Implant Complete)
Old 04-18-2010, 09:53 PM
SpidrVII's Avatar
Cool. Do you have any info on my previously mentioned "starter motor wire connector" dilema?
1983 Porsche 944
Old 04-19-2010, 12:39 AM
Well I am working on it right now, so its half being nice and half I have to look it up anyway. All I am doing is searching this forum, clarks garage, and google. Nothing ground breaking here, enough people have had to work on the same things in the past where the info should be floating around the internet somewhere.
Old 04-19-2010, 09:59 AM
SpidrVII's Avatar
Vacuum Line Pic - trying to decipher.
Here's the line configuration.
1983 Porsche 944
Old 04-19-2010, 02:01 PM
