Just thinking out loud
mattdavis11's Avatar
A/C questions
fire away, I'm ready.
91 FJ80
84 Ram Charger (now gone)
Old 04-30-2010, 04:23 PM
unindicted co-conspirator
looneybin's Avatar
i prefer D/C
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 04-30-2010, 04:28 PM
Me too, but also I want cold air blowing thru the vents. I'm bored, doesn't matter the make.
91 FJ80
Old 04-30-2010, 04:49 PM
Head & Shoulders.
1983 944 - project mode
2002 Ford F150 - every other daily driver
1976 Honda Goldwing - the other days
Old 04-30-2010, 05:28 PM
That's shampoo & conditioning. lol
91 FJ80
Old 04-30-2010, 05:32 PM
You said Hair Conditioner didn't you?
Old 04-30-2010, 05:35 PM
Most likely. I forget. I should use some though. It's falling out fast.
I started the 944 for the first time in almost 3 months tonight. The battery was a little weak.
91 FJ80
Old 04-30-2010, 05:49 PM
is yours like mine? has refrigerant, working compressor but no cold air
1983 944 Guards Red (87' Implant Complete)
The compressor clutch on my 944 is not pulling in. Is there a fuse or relay I should check? Does the 83 944 have a pressure switch to interlock the compressor clutch?
Mark
'83 Porsche 944 NA
'90 Porsche 944 S2
Old 04-30-2010, 05:51 PM
Mine has cold air and works as it should, but tell me more, Vicious. It might be a vacuum leak or heater valve and blend door problem.
mjadair, have you run 12v to the compressor? The pressure switch is on the drier behind the driver side headlight.
There may also be a shorted circuit on the electrical board that is under the drivers side kick panel, to the right of the glove box. It depends on what is wrong with the compressor, hook it up with 12 volts with low amperage.
I would not run a compressor with little to no freon and or oil for very long. Only long enough to verify electrical problems.
91 FJ80
Old 04-30-2010, 06:00 PM
