Brucem206's Avatar
Need Help to identify Fog Lamp
I am looking for a fog light for my 86 930. I have an 930S splitter with integrated fog lights. I need the right side light. The complete light assembly measures 7-1/2" x 3-1/4"overall. It has 3 mounting screws and 2 screws to adjust the reflector. The numbers on the lens are... 24-420-r7, 21-630-r7and 24-620-r8 in the center, 2-A-118125 at lower edge. The rear wiring plug is a Hella #122349. The lens is approximately 140mm x 68mm on the face. The mounting holes are 70mm apart on the outside and 180mm from the one hole on the inside. Does anyone know which car this lamp came on or would fit on?
Old 05-18-2010, 05:44 AM
In the Fires of Hell.....
kdjones2000's Avatar
Methinks you are in the wrong forum.... This is for 924/944/951's
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 05-18-2010, 01:45 PM
That sure looks to be the same as the 924 Euro light.
The lens numbers on mine are different but it looks to be the same mounting. The 924 has a hole drilled in the tab that sticks out on the side with the 2 mounting holes for the mini bumper. The sizes you gave are a bit rough but seem to be correct.
Shawn
Old 05-18-2010, 06:03 PM
Brucem206's Avatar
kdjones - I was told it might have been off a 924 or 944.
Buwani: Any idea of what year?
Old 05-18-2010, 06:23 PM
I think the Euro 924's 78 up to 82. Not sure what the S models use.
I think the Porsche number for the complete assy is 477 941 752 D.
Not sure if it is still available from Porsche. I know someone at 924.org that might have some used ones.
Here it is on mine.
Shawn
Old 05-18-2010, 07:21 PM
Used & Abused
Try this: Porsche 924S/944/968 Lights and Lenses - Page 2
Those lenses look similar to mine from my car though mine have a black plastic surround that goes over the housing.
83 - 944, daily driver
62 - VW Karmann Ghia, never moving restoration
"Oh Bother," said Pooh, as he chambered another round.
Old 05-18-2010, 07:23 PM
Used & Abused
the 924S used a round fog light iirc.
Old 05-18-2010, 07:28 PM
Idontknow, I looked at the 944 ones as they seem to have the same mounting but did not have the little tab for the mini bumper that is needed on the 924.
Looks like the 930 does not need the bumper so perhaps the 944 one would work.
Shawn
Old 05-18-2010, 07:39 PM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
My Euro 1986 924S has those fog lamps
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 05-19-2010, 04:08 AM
Brucem206's Avatar
Thank you for all the info guys, I think it is narrowing down. Euro is the common thread.
petrolhead611: Could you send some links for on line suppliers in the UK that I could investigate?
Old 05-19-2010, 07:07 AM
try porsch-apart.co.uk for used parts or partsforporsche.co.uk for new items.
Old 05-20-2010, 04:05 AM
lingham
I have both the left and right side lights. The Hella part numbers are 477 941 752 D and 477 941 751 D. Other numbers on the sticker are 1FB 002950-23 1FB 022 950-24. Below those numbers on both are 24 420 R8 24 420 R7. They are brand new and I have the original boxes that they were shipped in from Germany.
Old 11-25-2014, 04:44 PM
So, did you want to sell these in 2010???
Good luck, George Beuselinck
Old 11-26-2014, 07:49 AM
