rrwebster's Avatar
location of the under dash ground points
Can someone point me to where the ground points are within the interior (under the dash). Or... where is a good place to add an additional ground?
Having some issues that point to the ground not being good.
thanks in advance.
Robert
1983 Porshe 944 N/A 5sp Guards Red
Old 05-25-2010, 03:47 AM
Proprietoristicly Refined
John_AZ's Avatar
The big, multi junction, hard to find, hard to clean, is under the dash above the fuse/relay board.
When you are on your back looking up, check the wires connecting the fuses for burn marks, brittle sheathing or loose wires.
A small gound is behind the glove box for the AC components.
Begin by cleaning the bell housing negative cable ground. Put a piece of tape over the TDC hole to avoid dropping the bolt in the clutch.
Here is a photo from Techno Duck:
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 05-25-2010, 05:24 AM
rrwebster's Avatar
Thanks John,
it's still my power windows. new relay, new switches, when you work the switches the relay buzzes.
if I add a jumper from the window motor to the chassis the relay buzzes. if I remove the switch and jumper power and ground to the window switch plug, the windows work just fine.
Ground or something else?
Old 05-25-2010, 08:18 AM
I believe you answered your own question. When you jumped the switch out of the equation and the window worked. Either carefully take the switch apart and clean with contact cleaner or buy a NEW switch.
Cheers,
Larry
Old 05-25-2010, 07:24 PM
rrwebster's Avatar
Larry,
this is true whether I use the new switches I just bought, or the ones I cleaned up that were originally on the car. I thought new switches was the answer... but it's not.
in thinking about this... the only difference is ground... I am using a ground I establish when I jumper them... therefore I believe that it's the ground that's the problem... but then... what do I know?
Old 05-26-2010, 03:13 AM
Relay buzz is caused by bad ground or power, check connections for each. Likely the ground is shorting out
Old 05-26-2010, 09:05 AM
