Leak Question
Think I've found the reason for my slow little leak of stuff on the floor.
I went through my PO's repair receipts and saw one that listed a repair needed is a small steering rack leak.
Someone suggested something called Lucas power steering leak oil.
Is this a good idea to try first for this car? 1984 944
Old 06-28-2010, 03:29 PM
Can't hurt. May even temporarily stem the tide. Go for it and let us know how you make out.
Good luck, George Beuselinck
Old 06-28-2010, 03:37 PM
racer's Avatar
Well.. where is the leak showing up? Left side? right side? What does it smell like - oil? coolant? power stering fluid? brake fluid?
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 06-28-2010, 04:06 PM
Proprietoristicly Refined
John_AZ's Avatar
This is a temporary solution as George has pointed out.
Your system will drip less for about 6 months and then leak more. Porsche does not recommend any additive.
A rebuilt power steering rack & pinion is available with a lifetime guarantee at AutoZone. I got one a couple of years ago for about $180 exchange. Lifetime Guarantee
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 06-28-2010, 04:11 PM
Does this work like a perfume counter? I go to a store and smell all these, and then tell you, lol?
Tell me how those things smell, and I can identify. ;-)
Serious, though, I am just going by old receipts. Was basically curious if this would help for the moment, but don't want to add stuff if it will harm the car.
Thanks John, I'll check that out at Autozone.
By exchange, I take it that means I give them the old one ?
Old 06-28-2010, 04:31 PM
Oh yes, the leak is dropping on the floor in the front middle of the car hood, which , according to the repair manual is the location of the power steering fluid behind the radiator?
Old 06-28-2010, 04:33 PM
John_AZ's Avatar
There is also a power steering pump rebuild kit --$20 if the leak is on the PS pump.
Very easy to do in less than an hour,
John
Old 06-28-2010, 04:47 PM
Thanks for the video, that looks fairly simple!
Old 06-29-2010, 05:16 AM
racer's Avatar
My brief experience with the 944 power steering is that there can be several sources for the leak.. the pump, the rack, the resevoir and the lines themselves. They snake all under the car and have a myriad of connections. Removing the engine undertray, if you still have it, could help identify the leak a bit better.
Color too.. Greenish (or pink) is often coolant. Dark brown/black, tends to be oil. Dark red tends to be power steering fluid.
If you think it is a P/S leak, be sure to check the fluid level in the resevoir to prevent it from running dry. iirc, it is checked with the motor running. ON the bottom of the lid a dipstick is attached. If there is no fluid on the stick, thats a problem.
Past:
Old 06-29-2010, 06:50 AM
Toofah King Bad
Rasta Monsta's Avatar
Most common leak point is the hose from the reservoir. . .with age, the clamp can't get small enough to tighten the hose (clamp and hose were both superceded).
I would NOT put Lucas power steering fixer in the system, in case it is mixed with power steering fluid. . .our cars take ATF, and PS fluid kills the seals.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 06-29-2010, 08:01 AM
John_AZ's Avatar
Rasta is correct.
Upgrade/replace the hose from the reservoir to the power steering pump with the new upgraded "short" hose and fitting.---Pelican
Do not cut the hoses shorter. Maybe trim the hose 1/8 inch or so and drop the clamp down.
John
Old 06-29-2010, 08:30 AM
smokin_944's Avatar
I would NOT RECOMMEND the new fitting for Series 1 cars John, as I did this job last week. Because of the angle on the power steering pump, once the hose is on the fitting it will rub against an oil return line mounted on the chassis. Don't waste money for nothing, use the old banjo bolt setup. That way the chassis doesn't come into play and the setup is super clean.
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 07-01-2010, 09:09 AM
smokin_944's Avatar
How the h*** do you post pics again? I'm strugglin...
Old 07-01-2010, 09:55 AM
The little square at the top of your post "insert image" with the left arrow above, or below click to upload photo
Old 07-01-2010, 10:07 AM
Toofah King Bad
FWIW, I installed the hose update on my 924S, and it isn't rubbing anything.
Old 07-01-2010, 12:08 PM
ernie9944's Avatar
I will call this reply educating (Tressa ) the new Porsche owner to the world of 944 power steering.___Steering rack
__Pump
_Reservoir
__Hose PS to Rack
___hose Reservoir to pump
___Rebuilt kit
__And finally once everthing done just add some PS fluid to it
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 07-01-2010, 01:04 PM
Toofah King Bad
GAH! ATF only (although I see that Redline PS Fluid claims to be compatible with cars requiring ATF)!
Old 07-01-2010, 01:42 PM
Thanks guys! Love the visuals!
Old 07-01-2010, 02:00 PM
smokin_944's Avatar
updated fitting
I think this shows the fit...
Old 07-04-2010, 07:34 PM
smokin_944's Avatar
Note how the hose rubs against the oil return fitting. Not good...
Old 07-04-2010, 07:35 PM
