Rusty front rotors..no problem
While waiting for parts to install my new KONI front conversion on the struts I tackled a few cometic issues,,,easy to clean up your rotors if you dont have the ones with the coating on them...a power drill and a good wire wheel..about and hour each side..and really shined up the calipers too....
That Guy
Hope you wore atleast a dust mask
.Give them a coat of high temp paint if you want to keep them from rusting.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Your rotors look great but I would recommend putting on a coat of paint on the rotor hats or they will be rusted in just a few months.
The factory spec is to paint with grey primer and then a light mist of silver. I did mine and it took about an hour to remove and paint - I reinstalled in the morning. I did this a couple of years ago and they look as good as new today. Here's some photos of my project: New Rotors after about 4 months had rusted hats: ![]() After painting the rotor hat: ![]() Made a paint shield out of a manila file folder: ![]() Installed:
you'd better take care of those calipers (and rotor hats) or they will rust like a b*tch. the calipers are cad plated from the factory, and when you strip the cad plating, you open them up to unmitigated oxidation. i'd go with black caliper paint, because i like things understated. some prefer red. to each his own! the rotor hats look good painted, but i'm not that into making my car perfect... i'd rather go drive. vroom!
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme '88 951S - zermatt silber/black - staying stock. purchased in 11-2006 '84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001 2021 Tesla Y - to get me to work |
I started rebuilding my calipers one night this past week...wire wheeled the rust of the non-aluminum parts. I had rusty boogers for 3 days. +1 on dust mask.
1983 944 - project mode 2002 Ford F150 - every other daily driver 1976 Honda Goldwing - the other days |
One apex at a time
The rusty buggers wont kill. Breathing the dust from your brake pads is a whole different problem.
Location: In a dumpster behind Albertson's in Los Angeles County
eeewwwwww brake pad dust...sure hope you had asbestos free pads
1989 944 NA Glacier Blue - SOLD IT 1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 081988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG Semper Fi |
