Broken Balance Shaft Belt
So, I recently became a new Porsche owner. After some reading I determined it would be a very good idea to replace the timing belt, as I had no idea when it was last done. Ordered the kit from PP.
When we got in there, the balance shaft belt was busted. We replaced both as well as the the rollers. Good thing that's the balance shaft belt and not the timing belt! | TweetPhoto Is there anything I should watch out for as I do not know how long the balance shaft belt was broken? It drives like a completely different car now! ![]() Thanks, Jordan
1990 Porsche 944 S2 - RoW car - Sold 2001 Porsche 911 Carrera 4 |
Look for cracks in fuel rail and funny oil pressure readings (indicating a cracked oil pickup tube.)
Good luck, George Beuselinck |
Thanks George!
Oil pressure readings are at 5, unless car is warm and idling then they go to a bit over 3. I'll check the fuel rail. Jordan
Did you replace the water pump, or know if it had been done recently? It is recommended to do the pump at the same time as the belts as you have to go through the same procedure to access the pump as you do for the belts. Also, a newly tensioned belt can put enough stress on an old water pump to cause accelerated failure.
Also, don't forget to retention the belt after break in period, which I've read is about 2k miles, but have seen recommendations for as little as 500 miles.
1985.5 944 NA 1972 Triumph GT6 1982 VW Westfalia 2003 F150 Supercrew 4x4 1988 F350 Regular Cab 4x4 |
Thanks! I did not replace the water pump, as it looked good, with no leaks. I will definitely do it on my next belt replacement in 2 years.
Proprietoristicly Refined
Hi Jordan,
You are lucky the BB did not catch into the cam/timing belt. Make sure you retension the cam belt in 1500-2000km or so. Nice buy: quote: " ROW vs NA - differences I recently purchased a 1990 944 S2 ROW car. It was imported from Japan. My question is, what are the differences between the NA and ROW cars? The obvious: - My Speedo and Odo are in KM's... My answer-----Maybe nothing for the 1990 944 S2 between the US & ROW cars out side of interior options. 2.0 Model Outline The most important feature about the "S" is the cam chain and pads. You must service the cam NOW--especially the way the BB( balance belt ) condition was. You will have a very expensive repair if the cam chain snaps. The Pads wear down. John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Lucky RL felow member 944S owner found those two camshafts teeth stuck to his drain plug magnet asking the question here to peoples with lot of experience with 16 valves heads,how would them darn teeths found there way from the head to the drain plug ??? ,in the second pics shear teeth location ,third pics broken pads.
