uvachief
Mine is missing the left and right hood insulation pads. Is all that is needed to install a new one simply applying adhesive and sticking it to the underside of the hood? What adhesive would you recommend that won't melt and come away being exposed to the engine heat? Recommend any pad over another? Can you get one with any sort of emblem or stiching in them?
Sincerely, uvachief ![]() 1986 944 NA Red 5SPD |
Burn the fire.
It's best to run without the foam insulation pad.
Makes a great firestarter than anything else.
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
The pad comes with its own adhesive backing. Just peel and apply. You could also use 3M adhesive to ensure it sticks better. Before applying, ensure that you clean-up all previous applied glue and whats left of the old pad...if it's there.
Hope this helps.
Ed Paquette 1983 911SC 1987 944S 1987 944 Manual (Donated to the Nat. Kidney Foundation) 1987 944 Automatic (Recently sold to another Pelican) |
Proprietoristicly Refined
uvachief
![]() Hi, So, ya need to replace the flaking hood installation that looks bad all over the engine bay. Put down a huge old sheet and carefully scrape away. The best answer? Let me google that for you Yes, I am a brilliant ![]() GL John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
Misunderstood User
There are many previous posts with pictures as to how to remove old pads and put new ones on. Now if you are putting pads on for the first time, the surface must be clean.
I don't know what year hoods came w/o pads but the early cars did have them. Many pros and cons on this board as to their usefulness. I have an 83 and I like the appearance of the pads. I replaced mine as the old ones crumble over time.
Jim 1983 944n/a 2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway |
Toofah King Bad
Classic 9 Leather Shop: Hood Bonnet Liner Heat Shields
I put these liners on my 931, with cheesey/cool graphics. It looks great. Somewhere on the website are the instructions for installation. . .the difficult part is locating the specialized adhesive (a 3M spray) that they recommend.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Hi you can also buy the hood liners from the link below.
Ideola's Garage: Products & Parts for Transaxle Porsches Cheers, Larry |
I replaced mine a few months ago with IDEOLA's as mine were making quite the mess on the engine. His are well priced and look good, though the recommendation to clean and use 3M should be taken to heart. I first used ACE brand spray adhesive, then NAPA, and neither lasted. Spend the money on 3M.
Only thing to note with IDEOLA's pad was that for my car, I needed to cut about half an inch off two sides to get it to fit.
1985.5 944 NA 1972 Triumph GT6 1982 VW Westfalia 2003 F150 Supercrew 4x4 1988 F350 Regular Cab 4x4 |
uvachief
Rasta Monsta post pictures of your replaced hood pad from Classic 9 please.
uvachief
This is way down on my list but I will probably get to this item this month. Can anyone post any pictures of their Classic 9 or Ideola's pad?
Toofah King Bad
![]() *clicky* rasta P.S. The poor fit around the scoop is not the fault of Classic 9. . .my own hack job, I'm afraid!
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc Last edited by Rasta Monsta; 02-06-2011 at 11:08 AM.. |
Thanks for the plug Grandad...and FWIW, last year I commissioned a 931-specific version of the hood liner...to get proper fitment with no gaps, you need just a tad extra material than simply using a cut-out from a modified 924/944 version, so I had Bob make up a template specifically for the 931. Also, my prices are cheaper than what you can buy direct...
15 981 GTS | 88 924S SE | 82 931 Holbert | 82 931 Rallye | 81 937 | 81 Euro 931 | 81 Weissach | 80 US 928 | 80 US 931 '941' | 80 US 931 | 80 931 GTR | 79 Sebring | 78 D-Prod Replica | 78 w/D-Prod kit | 78 Poli-Form | 78 Limited Edition | 77 Martini |
Dog-faced pony soldier
There are foil-faced ones that are pretty effective at preventing paint blistering/failure even on very hot-running turbo engines. Try here:
928 Motorsports - Porsche® Performance Parts - Hood Liners For The Porsche® The stock ones by this point will have crumbled to dust, most likely. Those "bling bling" ones with the graphics? Nah, unless you're into that whole boy-racer/ricer look. To each their own but not my cup of joe...
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Toofah King Bad
<-owes porkofile one atomic wedgie.
Bling bling? Really? They come without the graphics...those are add-on if you want 'em.
For $80 you can do the hood, trunk, floors, etc.... I used this stuff on my TR6. Made the car feel solid like a mercedes.
Sound Deadener Products FatMat Dynamat Xtreme Alternative ![]()
What me speed? Last edited by seafeye; 02-07-2011 at 04:18 PM.. |
And here it is later......anyone wanna help finish the wiring?
What me speed? |
Toofah King Bad
Don't forget this:
"Dude! You kicked my car.
You can use those sound deadening mats on the hood?
What me speed? |
Tags |
hood , insulation , pad |
