uvachief
uvachief's Avatar
Send a message via Yahoo to uvachief
Question Hood insulation pad
Mine is missing the left and right hood insulation pads. Is all that is needed to install a new one simply applying adhesive and sticking it to the underside of the hood? What adhesive would you recommend that won't melt and come away being exposed to the engine heat? Recommend any pad over another? Can you get one with any sort of emblem or stiching in them?
Sincerely,
uvachief
1986 944 NA Red 5SPD
Old 08-18-2010, 07:00 PM
Burn the fire.
Brando's Avatar
It's best to run without the foam insulation pad.
Makes a great firestarter than anything else.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 08-18-2010, 10:39 PM
TibetanT's Avatar
The pad comes with its own adhesive backing. Just peel and apply. You could also use 3M adhesive to ensure it sticks better. Before applying, ensure that you clean-up all previous applied glue and whats left of the old pad...if it's there.
Hope this helps.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 08-18-2010, 11:31 PM
Proprietoristicly Refined
John_AZ's Avatar
uvachief,
Hi,
So, ya need to replace the flaking hood installation that looks bad all over the engine bay.
Put down a huge old sheet and carefully scrape away.
The best answer?
Let me google that for you
Yes, I am a brilliant -----thanks to others.
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 08-19-2010, 05:06 AM
Misunderstood User
There are many previous posts with pictures as to how to remove old pads and put new ones on. Now if you are putting pads on for the first time, the surface must be clean.
I don't know what year hoods came w/o pads but the early cars did have them. Many pros and cons on this board as to their usefulness. I have an 83 and I like the appearance of the pads. I replaced mine as the old ones crumble over time.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 08-19-2010, 06:17 AM
Toofah King Bad
Rasta Monsta's Avatar
Classic 9 Leather Shop: Hood Bonnet Liner Heat Shields
I put these liners on my 931, with cheesey/cool graphics. It looks great.
Somewhere on the website are the instructions for installation. . .the difficult part is locating the specialized adhesive (a 3M spray) that they recommend.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 08-19-2010, 06:52 AM
Hi you can also buy the hood liners from the link below.
Ideola's Garage: Products & Parts for Transaxle Porsches
Cheers,
Larry
Old 08-19-2010, 10:04 AM
ewalt98's Avatar
I replaced mine a few months ago with IDEOLA's as mine were making quite the mess on the engine. His are well priced and look good, though the recommendation to clean and use 3M should be taken to heart. I first used ACE brand spray adhesive, then NAPA, and neither lasted. Spend the money on 3M.
Only thing to note with IDEOLA's pad was that for my car, I needed to cut about half an inch off two sides to get it to fit.
1985.5 944 NA
1972 Triumph GT6
1982 VW Westfalia
2003 F150 Supercrew 4x4
1988 F350 Regular Cab 4x4
Old 08-19-2010, 11:21 AM
uvachief
uvachief's Avatar
Rasta Monsta post pictures of your replaced hood pad from Classic 9 please.
Sincerely,
uvachief
Old 08-20-2010, 02:24 AM
uvachief
uvachief's Avatar
This is way down on my list but I will probably get to this item this month. Can anyone post any pictures of their Classic 9 or Ideola's pad?
Sincerely,
uvachief
Old 02-06-2011, 10:49 AM
Toofah King Bad
Originally Posted by uvachief View Post
Rasta Monsta post pictures of your replaced hood pad from Classic 9!!
Ja vohl, mein Herr!
*clicky*
rasta
P.S. The poor fit around the scoop is not the fault of Classic 9. . .my own hack job, I'm afraid!
Old 02-06-2011, 11:02 AM
ideola's Avatar
Thanks for the plug Grandad...and FWIW, last year I commissioned a 931-specific version of the hood liner...to get proper fitment with no gaps, you need just a tad extra material than simply using a cut-out from a modified 924/944 version, so I had Bob make up a template specifically for the 931. Also, my prices are cheaper than what you can buy direct...
15 981 GTS | 88 924S SE | 82 931 Holbert | 82 931 Rallye | 81 937 | 81 Euro 931 | 81 Weissach | 80 US 928 | 80 US 931 '941' | 80 US 931 | 80 931 GTR | 79 Sebring | 78 D-Prod Replica | 78 w/D-Prod kit | 78 Poli-Form | 78 Limited Edition | 77 Martini
Old 02-07-2011, 08:07 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
There are foil-faced ones that are pretty effective at preventing paint blistering/failure even on very hot-running turbo engines. Try here:
928 Motorsports - Porsche® Performance Parts - Hood Liners For The Porsche®
The stock ones by this point will have crumbled to dust, most likely. Those "bling bling" ones with the graphics? Nah, unless you're into that whole boy-racer/ricer look. To each their own but not my cup of joe...
Black Cars Matter
Old 02-07-2011, 09:41 AM
Toofah King Bad
<-owes porkofile one atomic wedgie.
Old 02-07-2011, 09:57 AM
ideola's Avatar
Bling bling? Really? They come without the graphics...those are add-on if you want 'em.
Old 02-07-2011, 10:05 AM
seafeye's Avatar
For $80 you can do the hood, trunk, floors, etc.... I used this stuff on my TR6. Made the car feel solid like a mercedes.
Sound Deadener Products FatMat Dynamat Xtreme Alternative
What me speed?
Old 02-07-2011, 04:12 PM
seafeye's Avatar
And here it is later......anyone wanna help finish the wiring?
What me speed?
Old 02-07-2011, 06:09 PM
Toofah King Bad
Don't forget this:
Old 02-07-2011, 08:03 PM
"Dude! You kicked my car.
Rudeboy42's Avatar
You can use those sound deadening mats on the hood?
Old 02-08-2011, 02:31 PM
seafeye's Avatar
They do have specific hood liners.....here is a peek...
FatMat xTreme Liner Kit Sound Dampener
What me speed?
Old 02-08-2011, 02:42 PM
Tags
hood , insulation , pad
