All Spooled Up
Penetrating Oils: Seafoam vs. PB, which is better.
I have always been a fan of PB (penetrating blast) brand penetrating oil, but a friend of mine just picked up some Seafoam brand (claims to be "the deeper creeper", and also claims to work "faster than blaster"), after someone told him it is better than PB. But to me, it doesn't smell nearly as good (potent) as PB, so I am skeptikal. Kin I git sum opinions on which is the better product?
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
Redline Racer
I didn't know Seafoam made a penetrating oil. I've seen a couple people here swear by a 50/50 mix of ATF and acetone, but I haven't tried that yet. PB is some of the best stuff I've used, but I'll have to see if I can find some Seafoam stuff and try it.
Dude! An official penetrating oil shootout...how awesome would that be! It could be that some formulas work better on ferrous on ferrous rust versus aluminum/steel corrosion we have to deal with, or vice versa.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
Proprietoristicly Refined
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
I have used all of these products and WD-40. I continue to use them despite never really noticing any verifiable results. Maybe they do work, I just can't prove it and it definitely doesn't make it more difficult. But for me, waking the bolts up and using impact goes a lot further. Brute force is great but by itself you run the risk of sheering or stripping heads.
1983 944 - project mode 2002 Ford F150 - every other daily driver 1976 Honda Goldwing - the other days |
Get rid of all the other junk and use the one, the only, penitrating fluid "KROIL".
Cheers for KROIL, Larry |
Dog-faced pony soldier
Seafoam deep creep is amazing stuff.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Good point. I had to put my dog down a few years ago when she got into the garage and chewed a hole into an unopened anti freeze jug. I am careful what I store in my shop now.
As in any oil based solvent product you have to read the WARNING label and store / use accordingly. You all read the Warning label on the product you are now using. Just about everything is a hazard to your health, even some foods.
Cheers, Larry |
pb blaster, and release-all are good.
Rick Harrison 1988 944S 17 inch Cup 2's, euro bumper conversion Magnaflow 2 1/2" exhaust with K & N 4 inch custom intake MaxHP chipped |
none of the above
50/50 ATF/Acetone :P |
if you use the ATF/acetone mix, how do you spray it on the bolt/nut, if it's not on a flat surface? Not being in an aerosol can that is..
M |
I use Kroil on firearms and it is amazing at lifting crap out of bores long after you would think they are clean. Its 100% compatible with German steel
1985.1 Porsche 944 (Progress Thread) |
Just thinking out loud
This is the best stuff I've ever used.
![]() There is one time, which I remember quite well, that I wished I'd had some. I was removing the rear evaporator on a Suburban that had seen lots of salt from the northern regions. Liquid wrench took over after wasting my time with PB blaster. That was the hardest, most time consuming a/c job I've ever done. Every union required multiple rounds of heat and oil. 1/4 turn about every 30 minutes on every union. I went through a couple of wire wheels on my dremel cleaning the union threads. It was horrible, and I was the one caught with my pants down by not having the aforementioned oil.
83 944 91 FJ80 84 Ram Charger (now gone) |
I have had good luck with Kroil.
1989 911 Carrera Cabriolet Black SW Chip, M&K Pre-muffler and 1:1 Muffler 1983 944 Spec project car RIP |
Parrothead member
Ive been a Seafoam convert for a few yrs now. Good stuff
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
I would definitely use KROIL. What it loosens is nothing short of miraculous. Good luck
Ted A. '67 912 '71 914 (2) '82 928 Weissach '85 944 n/a |
Parrothead member
All Spooled Up
It looks like I opened up quite a debate with this thread. Other than seeing some products that I was not familiar with, there doesn't seem to be anything definitive (so far, anyways). I'm going to have to try the home-made product mentioned, as I do have the necessary ingredients.
