Question Cost to rebuild 86' N/A engine
may be able to pick up a 86'944 N/A with no belt,..so whats the general cost to rebuild that engine,...Thanks Frank
Old 09-08-2010, 10:14 PM
Check here for the head gasket set, cam housing gaskets, new cam gear bolt, front engine seal kit and oil pump sleeve, oil pan gasket, Check oil pick up tube and new gasket, timing belt kit, updated water pump NEW, rod bearing kit, New AOS Seals, dip stick seal, have the head checked and machined, send off injectors for clean and new o-rings, Put in new RMS and as you can see the list can go on and on as you find other things to replace.
Cheers,
Larry
Old 09-08-2010, 10:43 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Realistic worst case scenarios are a snapped timing belt (new valves, possibly new pistons, possibly a new head), an overheat (warped head), a spun #2 rod bearing or either a blown out head gasket or oil cooler seals.
Any of them are fixable by a dedicated DIY-er. Or you can buy a used n/a engine for around $1k and transplant it in for about the same amount of effort, get the car running and then figure out what's going on with the original engine while it's out of the car and on a stand where it's easy to work on. That'd be my recommendation.
Black Cars Matter
Old 09-09-2010, 02:49 AM
Redline Racer
HondaDustR's Avatar
It cost me about $2500 for the works with no serious problems to fix, including all the tools I needed and some clutch parts, $500 for the engine, and $200 to balance the bottom end. I did the cylinder honing myself, and determined I did not need to to any work to the head as it looked like it was previously rebuilt. It's not cheap if you intend to replace every bearing and every seal, but if you know your bottom end is good, just head work from a broken cam belt shouldn't be more than about $1000 tops after all is said and done...possibly cheaper. Sometimes it's cheaper to find a good used head, freshen it up, and swap in. Depends on how many valves are bent and if there's any other damage.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 09-09-2010, 11:20 AM
I'd say about 5K for a reliable race engine with all the right pieces and 3K for an OK street engine assuming the crank and journals are in spec. Most of the time the cheaper you try to be the more it ends up costing you!
brant giere
2005 996 cup
1991 964 euro cup (Larbre #28- race
1987 carrera 3.2-street/de car
1962 Austin Healey 3000
Old 09-10-2010, 06:49 PM
porscha
matty89's Avatar
i just rebuilt the head and 5 valves its about 1k with the t belt kit and the machine shop work ! im rebuiding it 2day in matter in fact ! good luck ! matt
Old 09-11-2010, 07:05 AM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
Zims and Lindsey Racing offer complete overhaul kits; rod & main bearings, balance shaft bearings, all gaskets and seals, valve guides, connecting rod nuts (NO! your removed connecting rod nuts are not reusable!) and piston rings for your engine (85/2-86 $875 Zims).
Or all the above parts plus; the balance shaft bushing, locktite 574 block sealant, assembly lube, engine block freeze plug, piston pin clips and oil pressure relief valve seals from Lindsey is only $809.95.
Then add in your machining costs and begin the fun, I did one for a friend, and it came out to roughly 2k.
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 09-11-2010, 08:00 AM
dkbautosports.com
962porsche's Avatar
i just spent 9,673.00 to rebuild my 944 spec motor this spring . that was with a new clutch too .
Old 09-11-2010, 07:07 PM
cjpacitto's Avatar
Lindsey's website says they'll do the entire rebuild for $4500. That includes all cleaning, machine work, honing, parts, and assembly. Knowing what I know now, that is actually a pretty good deal.
Old 09-12-2010, 02:32 PM
dkbautosports.com
962porsche's Avatar
is that with a new oil pump , water pump and belts , pulleys , gaskets ans so on ? i would think thats just the bare block with pistons and barings .
Old 09-13-2010, 05:30 AM
dkbautosports.com
962porsche's Avatar
i just checked out lindsey racing . you better read just what you realy get for the price . one thing they offer as an up grade is the mahle pistons . the OE STOCK pistons that came in your 944 are mahle . so they are not up grading what porsche used . the up grade is only on there end .
Old 09-13-2010, 05:51 AM
I've said it before and I'll say it again... Take EVERYTHING you read put out by the lindseys with a grain of salt. They are not the experts that they make themselves out to be. They do have some nice products but do your due diligence before using anything they sell.
I won't say more in a Public forum. I do buy a few parts from them, mostly out of convenience.
If you are looking at a non-stock build I suggest Paragon Products. These guys really know the 944s.
If you are going back stock I would look at Pelican.
Old 09-13-2010, 07:49 AM
