Send a message via AIM to ScoobySteve
How to bend 4 valves without a snapped t-belt and proper timing
Story time....
I recently managed to bend 4 valves just 30 miles after picking up my 944 mechanic. Timing belt is intact and timing marks are dead-on. How did I do it?
I recently dropped off my car at the mechanic due to a popped coolant expansion tank hose. Mechanic calls me up and says he thought he had it fixed but it is now spurting out oil on the exhaust side between the head and the cam tower. This is not a small leak but one which will drain a quart of oil every 10 minutes. He suggests we tear down the cam tower to check the head and see what happened. He asks me how hot the car got...I told him it didn't even get to the red and I didn't drive more than 1/4 mile with it at elevated temps.
I get a call 2 days later. Car is ready! (w00t!) Head was fine....threads in the head holding cam tower bolts....not so much. He time-serted 6 threads for cam tower bolts. A moderate size bill and I'm back in business...for 30 miles.
I'm literally a mile from home, accelerating normally at about 3500 rpm when I hear a pop, metallic bang, and then a sound I can only describe as "expensive." I didn't even try and restart it, figuring I had just popped the timing belt. Looking under the hood through the distributor housing inspection hole and the timing belt had proper position and still looked to have perfect tooth engagement. I had the car towed back to the mechanic and he called me later that day saying he was puzzled. The belt had not snapped and the timing marks were all correct, yet I had no compression on 3 cylinders. His theory was that a valve seat may have dropped into one cylinder, had fragments break apart, and been sucked into the other cylinders causing damage. The head needed to come off and he told me not to worry about the cost for that.
Fast-forward 2 days and he calls me. He says he needs some time and I thought he was talking about the tear-down. He was talking about the repair and issued his profuse apologies as he had solved the mysterious failure. It turns out he had forgotten to torque one of the interior cam tower bolts. It backed out and managed to lodge itself into a cam lobe. Here's the tricky part, it didn't stay lodged in there. It wedged into the cam lobe just long enough to result in 4 bent valves but not long enough to overstretch and snap the belt. So basically the head needs to be redone, the cam tower has a chunk taken out of it, and the cam is toast. Mechanic is covering everything.
-Stephen
00 Boxster S 6MT
03 Subaru WRX w/EJ207 swap
16 Cayman GT4
21 Genesis G70 3.3T
Old 09-24-2010, 09:48 PM
That's some bad luck.
I'm glad to hear he's covering it. Would have been easy for him to try to blame something else.
Will he clean out the oil pan of metal fragments and change the oil too?
1990 944 T: 100 000 km/63K miles,
1997 986 2.5L: 95 000 km/60K miles,
Living in the trackless land of plenty!
Old 09-24-2010, 11:57 PM
one of gods prototypes
bell's Avatar
Yea that sucks, but, any good honest mechanic will cover his mistakes and come clean about it.......
Imo mistakes do happen, it's at those times you find out what people are made of.......
I'd give him reasonable time to correct his mistake, he probably still needs to do some paying jobs to put food on the table......
Brought to you by Carl's Jr.
Old 09-25-2010, 05:13 AM
Unhappy
If my mechanic forgets to torque a very important internal engine bolt, I will not trust any engine work from him. I will be worried whenever I take my car out for a drive.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 09-25-2010, 06:13 AM
Toofah King Bad
Rasta Monsta's Avatar
Man, rough to make a mistake in that line of work!
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 09-25-2010, 06:52 AM
I'm not mad and I've used this mechanic for over a decade and never had anything which required a repeat visit. Last time I was in his shop he had a 250,000 mile 944 in there. If anything, I'm just frustrated because I seem very unlucky with cars lately. In the last 4 months I've been towed 6 times between both cars. So I'm just getting tired of what seems like horrible luck with both cars.
-Stephen
00 Boxster S 6MT
16 Cayman GT4
21 Genesis G70 3.3T
Old 09-25-2010, 08:16 AM
smokin_944's Avatar
Imo mistakes do happen, it's at those times you find out what people are made of.......I'd give him reasonable time to correct his mistake, he probably still needs to do some paying jobs to put food on the table......
+1 bell I think LAdy Luck is on your side. An honest mechanic is golden IMO. I work on my car in company of The German from ******** and he's a detail freak so he watches me like a hawk whenever we wrench. Sounds like you'll be alright other than the no P-car situation for awhile. Good luck getting this sorted out!
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 09-25-2010, 09:03 AM
Just thinking out loud
mattdavis11's Avatar
Wrenching on your own stuff is therapeutic. It's not hard.
91 FJ80
84 Ram Charger (now gone)
Old 09-25-2010, 09:10 AM
he probably torqued the cam tower with the cam in the wrong position and the engine on tdc.
86 951 well modded
94 968 Iris blue daily driver
Old 09-25-2010, 12:35 PM
All Spooled Up
The gig is that you need to be at least + or - 45 degrees (90 would be the safest) from TDC on the crank, if you are bolting on the tower or moving the cam around. Once the cam is aligned, THEN bring the crank in to TDC.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 10-31-2010, 08:33 PM
Back from Beyond
Everyone makes mistakes. This guy's honest enough to admit it and man enough to cover all of it at his own expense. You know how rare that is?
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 11-01-2010, 10:52 AM
