GJF GJF is offline
Slantnose from HELL
GJF's Avatar
Removing A/C lines that go into firewall???
Hi Guys,
The A/C hard lines that go from the engine bay through the firewall to the evaporator. Are they just pushed in with o-rings? How do they stay connected?
It changes from time to time.....
Old 09-25-2010, 09:32 AM
KEV951's Avatar
each line has a 6 pont 10mm bolt on an ac flange on the firewall that must be removed
Old 09-25-2010, 11:04 PM
Roman944's Avatar
you are removing - plan to sell them or put them back in at a later time? I just hacked mine off
Old 09-26-2010, 04:35 AM
Aslet's Avatar
I cut them and pulled...
-Randy
1984 944 -Race car project
1993 968 coupe- Amazon Green
Old 10-01-2010, 05:54 PM
I have a 1983 and they pass through the firewall with a 1 piece double grommet then connect directly in front of the evap housing.
Old 10-02-2010, 08:19 AM
jetmax's Avatar
Send a message via AIM to jetmax Send a message via Yahoo to jetmax
I started up a new thread, but just in case any of you are subscribing to this one.
I have an s2 with o-ring leaking from firewall. I can get a socked and wrench on it, but do not have enough room to turn it. And suggestions on how to remove it to put new o-rings in with out hacking them off?
1990 944S2 Cab - over 215k miles
jmaxvill@hotmail.com
Old 11-18-2012, 07:39 AM
You can get a 1/4 drive socket to turn a click or two on an N/A. Remove the clamp holding the wiring harness bundle and push it aside for a little more room.
Old 11-18-2012, 03:41 PM
jetmax's Avatar
K, i'll look to move the clamp holding the wire harness. You can see the corner of the valve cover on the S2. I guess going from the top is the way to go then. You can see the dye that's leaked around the hose.
Old 11-18-2012, 05:46 PM
