How to clean the engine
Now that the head is off the car,...whats the safest way to clean the engine area,...I want to presure clean the engine after I cover up all the pistons,.. is this a good or bad idea. Thanks FM
If the head is off washing it will put water in the Oil passages/pan. I would wait till you put the head back on , spark plug wires in, and all vaccum lines hooked up. Then just cover up the Throttle body with a trash bag and some tape.
You can always use some Carb or brake cleaner if you need to the deck before that...
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles |
put head and cam back on and pressure wash , otherwise seal the deck with duct tape or masking tape and use brakeleen and a wire brush, safest and most controlled way, also, tape up any open water, air, and oil ports.
When I did mine, I stuffed rags in each cylinder and then taped the deck of the block completely with aluminum tape. I would not "pressure wash" with high pressure.....apply a good degreaser, let it soak for a while, brush wherever possible, and then rinse at low pressure to keep water from getting into places it shouldn't.
1988 944 Turbo Guards Red - Black Leather Autothority Stage 2 Chip Set Weltmeister Strut Tower Brace 1984 944 - Sold to rcecale |
Thread Tools | |
Rate This Thread | |
