Speed and Reference sen. issues...
ohm results
speed sensor - terminal 8-27 ------ .955 M ohm
terminal 8-23 ----- 33.5 k
reference sensor - terminal 25-26 --------- 155.9k
terminal 25-27 -------- 1 result was 33.5 k the second was 1.115 M
what does that mean for me ^^^
I'm still trying to hunt down a intermittent starting problem. that seems to be getting a bit worse. a couple days ago i heard a sound (after it didnt start for a while) that sounded like the sensor it self was touching the flywheel for a second. this only happen happened very briefly on that drive home 2-3 times and only while i was slow starting from first gear.. didnt do it in any other gears ... didnt do it during neutral either. never heard it again
in this picture from cg my sensors dont match.. is that from an early 944 or 924. cuz my sensors dont seem to have that bracket or whatever between the housing and the sensor. its all tight . no loose or missing bolts
Old 10-31-2010, 11:36 AM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
It may very well be that the OP changed out one of the sensors in the past...
That loose ground wire - the main ground for the motor is loose - big problem - the brown one in the picture and a couple of inches to right of the sensors looks like it is completely loose.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 10-31-2010, 12:09 PM
that wasnt my photo..
Old 10-31-2010, 12:42 PM
Garage Helper
Oops - sorry about that - looks like someone's ground is loose.
Old 11-01-2010, 12:01 AM
S ECU Repair's Avatar
Here is some info that can help you .!
Jose
Specialized ECU Repair
Porsche Bosch Motronic DME Specialists
Free DME Testing for Pelican Parts Members
www.ECUdoctors.com
1-800-328-1425
Old 11-04-2010, 08:52 AM
