Amurley's Avatar
Question Annoying Problem....
I have an annoying problem with my 1985 1/2 Porsche 944. This problem comes and goes (almost with weather changes). Last year I stored my car and when i took it out there was a problem that once you hit 1800 - 1900 rpm I lose all power but the car does not cut out... it just drops to idle speed and once it hits 1800 - 1900 rpm it drops again.
At first I thought it might simply be bad gas... no such luck . The car has gone through a few tanks of fuel since then.
Next I decided to do the cheapest thing (seeing as i'm a student) and i replaced the fuel filter... no such luck... the problem returned.
The problem usually goes away for weeks at a time with regular city driving but returns with any aggressive driving or spontaneously just for fun .
As today is groundhog day I would like to get my car ready for the road again (we have too much snow and road salt for me to drive in the winter). If anyone has any idea what is happening please help.
Some unexplored or slightly explored areas are vacuum leaks and fuel pump.
Also, I was told that the car had a computer (to my surprise) and would like to know the "codes".... Thanks, Amurley.
Old 02-02-2002, 10:42 PM
Amurley's Avatar
When I said power by the way I meant push power... not electrical... just thought I'd add that.... thanks... any help is greatly appreciated...
Old 02-03-2002, 09:47 AM
Magnus_944's Avatar
Lightbulb
I might be the Throttle Position Switch. Check it according to the Haynes manual.
//Magnus
944 N/A '83
Old 02-03-2002, 10:00 AM
Amurley's Avatar
ok... thanks... i'll check that out...
Old 02-03-2002, 10:02 AM
3sonfather's Avatar
This can be a real bear to solve. I chased a rev limiting condition for months - couldn't get above 4500 rpm. I replaced what looked like a bad speed sensor still to no avail. Then I began to tinker with the air flow meter and found I could change the point that it would cut out by adjusting the wiper position. This also made the car run rich or lean depending on the setting. Ultimately I swapped out the AFM and that cured my troubles.
Old 02-03-2002, 12:25 PM
Amurley's Avatar
is it a pricey procedure to replace the AFM (air flow meter)?.... I'm making a list of possible problems and i'm going to sort it from cheapest to most expensive i've got a little time because the damned groundhog saw his shadow and that means six weeks more winter (at least).
Old 02-03-2002, 01:56 PM
Crippler's Avatar
Sorry for this being totally unrelated, but I was just wondering what part of Canada you live in.
Old 02-03-2002, 02:04 PM
Amurley's Avatar
Eastern Canada... New Brunswick... which leads to another problem.... the nearest authorized dealer or service centre is in Ontario...
Old 02-03-2002, 02:07 PM
Crippler's Avatar
hey, I live in Fredericton. Where do you live in NB?
Old 02-03-2002, 02:09 PM
Amurley's Avatar
Fredericton....
Old 02-03-2002, 02:12 PM
Crippler's Avatar
Well that is interesting, what's your name, what does your car look like?
My name is Kent Staples and here is a pic of my 1984 944.
Old 02-03-2002, 02:14 PM
Amurley's Avatar
Andrew Murley... have i seen your car on campus?...
Old 02-03-2002, 02:16 PM
Crippler's Avatar
yup, its the only black 944 on the unb campus that I know of. I just wish all of this snow would go away so I could get it back out. Is yours red?
Old 02-03-2002, 02:18 PM
Amurley's Avatar
my car is red and in need of some cosmetic work (besides the problem that made me join this forum).
Old 02-03-2002, 02:19 PM
Crippler's Avatar
There are not many 944's here in Fredericton, but here are the one's I know of.
White 944 n/a (late dash)
1989 944 black (is never driven has engine troubles)
944 turbo of some year, red and lives in New Maryland, I have never seen it,but have heard of it.
My 1984 944
and your 944
Anyways it is nice too talk to some one in the city with a 944. Oh and sorry I can't be of any help with your problem.
Old 02-03-2002, 02:27 PM
Amurley's Avatar
There is also a gold coloured one... i saw it last year.. had any service done in town?
Old 02-03-2002, 02:38 PM
Crippler's Avatar
I had my belts (timming, balance) done at york auto service, uptown off bishop drive. They overcharged me on the belts, but they did know what they were doing and did a good job. So it was worth it because they are not something to fool around with. I do all the rest of my service myself and order most of my parts from the Porsche dealership in Calgary. I have also ordered a few from Performance Products, but it is usually alot cheaper to order from the dealership.
Old 02-03-2002, 08:17 PM
Send a message via Yahoo to Cebu
Your problem associated with weather, and hard acceleration..I too, would suspect the AFM as a priimary cause of RPM instability. Air density/temp. weather related and underhood temperature related to driving time and hard acceleration.
Old 02-04-2002, 05:32 AM
Amurley's Avatar
ok... thanks... i'll definately check that out asap.
Old 02-04-2002, 10:22 AM
Amurley's Avatar
Cool
Cool... any idea what a throttle switch will run me?.... Thanks alot... mechanics around here don't know **** about these cars... except one guy...
Old 02-04-2002, 01:59 PM
