Banned
still rough cold idle after dme temp sensor replaced
i've checked the afm, the afm temp sensor, and checked out the vacuum lines to the best of my ability. do not have any way to do any compression tests on the manifold/vac lines at this time. fuel economy is poor, rough idle is not nearly as bad as before i replaced the dme temp sensor, but is still present.
any ideas? |
the AFM have a regulation,maybe you have an errating adjusted CO value when cold and then when the car warm up the O2 sensor engage the right mixture and the iddle was better
i have an AFM open from someone and probably he change the spring relation the car have poor idle and performance and sometimes dificult to start i change the AFM and now is OK try to see the ignition colil,distributor,spark plugs... try to disengage the iddle valve,maybe is faulty if you have an 85/2 car try to set a higher idle(1100) when warm and see what happened when cold..
porsche 924 carrera gt 90% ready porsche 944 NA 86' half 951 951 full project for 944 chrysler 300M 6 x 924 and 944 canibalized or death |
Banned
brand new plugs gap checked before install lightly sanded the cap and rotor contacts to reveal clean brass underneath no arcing visible from plug wires if i can find a procedure on clarks garage for the c0 setting i will check it out in a second Last edited by fwayfarer; 05-01-2011 at 03:30 PM.. |
Proprietoristicly Refined
Check the FPR & FPD for gas leaks. Pull the vac hos off of each and look very carefully for any gas moisture.
Check and clean all electrical connections on top of the engine. Rebuild the TB (throttle body) with a $20 kit from http://www.arnnworx.com/catalog/ Check the alternator output and battery condition. Link to www.the944.com ©1999 FR Wilk for CO +++ information. GL John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
Banned
either way battery is getting replaced asap, hopefully that's the problem.
I spent a couple of weeks getting my '87 idle to stop the 925-1050 rpm fluctuation.
Part one. Swapped alternators (after I tried a new VR) when I found the battery was not being fully charged. The old alt put out enough to keep the idiot dash light out and start the car. I used a hydrometer on the battery and the cells did not charge into the "green" mark. Battery OK with load meter. Part two. Cleaned the ICV/ISV with Gumout throttle body and fuel injector cleaner. Cleaned all elecrical connections on engine. Tightened hose clamps and replaced a couple of small pinch clamps with fuel injector hose clamps. Part three. I replaced the ICV/ISV hoses and the plastic connector under the "J" boot. Part four. Pulled the FPR & FPD vac hoses for the 3rd, 4th 5th +++time. Saw gas moisture in the FPD! Replaced FPD. Idle now is steady at 999rpm ![]() Conclusion: The car is like a mature woman. Some times you have to do many things to make her happy. GL John
What does FPD stand for?
1982 944 RHD (945), Lhasa Green |
FPD=fuel pressure damper
FPR=fuel pressure regulator John
I see! I knew FPR, but didn't know there was a damper - is it on the fuel rail?
Yes, the FPD is toward the radiator, the FPR is at the rear firewall side.
John
Thanks John.
Darren
