944 addict
engine stand
I'm thinking of pulling the engine and putting it on a rotisserie stand so I can get at EVERYTHING. Anyone with pics and info on making this a "no-brainer", your input would be appreciated. Are there any issues in mounting the motor on the engine stand?
Custom User Title
I just bought one from O'Reilly, and it works great. This one: ACDelco 34125 - Engine Stand | O'Reilly Auto Parts
I'd never used one, and initially, we had a helluva time getting it hooked up to the bellhousing bolt holes. Finally, we hit on the easy solution: rather than holding the engine steady on a chain dangling from the hoist and trying to position the engine just so (which just wasn't working), we pulled the whole bracket off the stand (you pull the handle out, and the whole holder assembly just pulls out). Once we had the holder bracket off the stand, we easily bolted it to the bellhousing holes, then with the engine on the hoist, jockeyed the engine and holder tube assembly back into the stand. Voila!
83 944 NA - Black on black 86 951 - Red - SOLD 7/21 16 Ford Expedition He who hesitates is lost. Last edited by mikepellegrini; 04-29-2011 at 08:16 AM.. |
That Guy
You will need four M12x1.5 bolts, i think i used like 90-100mm and a few washers and large nuts as spacers. Two of the original bell housing bolts will work aswell as all 4 crossmember bolts, but unless i am in a pinch i prefer not to use those.
Here is my spare engine on a stand.. makes life alot easier.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
I got the 2000LB one from harbor freight, and it worked well (paint was all getting chipped off though, typical Chinese quality.) You have to take the bell-housing off of the engine, first though if you want to put it in that stand.
Edit: Here is an example to go with Mikes ![]()
Custom User Title
83 944 NA - Black on black 86 951 - Red - SOLD 7/21 16 Ford Expedition He who hesitates is lost. |
+1 for bolting the arms onto the engine then sliding it into the stand...
my 60 year old father and i lifted the complete engine onto the stand with no problem
944 addict
a 2000 lb engine lift? Is that really necessary? I don't know how much the engine with accessories weigh and Harbor Freight has one a lot cheaper that has 1000 lb capacity. If I'm being a bit foolish its ok to weigh in on me about this.
944 addict
Hey Red Baron, did you drop the engine out the bottom? I noticed the cross member bolted to the engine on the stand.
944 addict
Did you drop the engine out the bottom? I saw the cross member bolted to the motor while it's on the stand and was wondering. It looks great. Do you think the 2000 lb stand was overkill or do you think the 1000 lb stand would be sufficient.
This was beginning of removal with a simple harness: ![]() This was beginning of installation with a bracket made of uni-strut at the bottom to help support it:
Redline Racer
The 2000lb stand will most likely feel more solid as you work on the engine, but the 1000lb will be plenty. I think mine is the 750lb job from Pepboys and it worked fine. If you don't have a lift, the engine is light enough to mount the bracket up, lay the rest of the stand down to connect to the bracket on the engine while it's on the ground, and just tip the whole thing up to stand it up, which may require help depending on how much of the engine is there. A short block is manageable with 1 person. I did my engine swap without a lift and it was a PITA, but doable.
The larger transmission bolts work for mounting the bracket as well. I was lucky and have a big paint bucket full of scrap 944 hardware I bought off someone. It's next to impossible to find large metric hardware like that locally, at least at the usual consumer grade hardware and auto parts stores.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky Last edited by HondaDustR; 05-06-2011 at 07:54 AM.. |
944 addict
Barn?
Dog-faced pony soldier
Piece of cake. Word of advice - drain the oil before turning the engine on its side or upside-down. It saves a hell of a mess.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
944 addict
I can't lift the car that far off the ground. Maybe I'll dig a pit in the garage.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
