Ignition issues, no spark
How much fun can one guy have with these cars? They're great when they're running and a nightmare when they ain't!!!!
1987 924S, mechanic's seem perfect, compression, timing on the mark. Normal no spark issues are right on, sensors, ecu, fuel pressure, injectors have pluse, just rebuilt and tested. Ran ECU Doc's DME pin checklist, here what I got (rest are on spec)
Ignition coil (coil is tested and known good) ignition on, (pin 1 and ground) 12.4 volts, startp position dropped to 10.3 v in start position, no real pulse
Idle switch show no continuity l(pins 2 and ground - throttle open
Tach and upshift light (pin 11 and 21, ign. Off) no continuity,
Volume airflow (pin 22 and ground) no voltage with ign. On
All mechanicals are perfect and within spec. Not sure if any of the faults listed would prevent the car from starting, might cause a ratty running engine, but it should start?
Old 06-22-2011, 06:14 PM
no spark
my 84 944 has no spark. sprayed starting fluid in air box...no start/or attempt to run. pulled spark plug and grounded, crank..no spark
coil ohm 0.6 ohms
rotor spins when cranking
no continuity from the carbon button to the post on the top of distributor cap
spark plugs appear good
i ordered a new dist cap and rotor and will ohm out then install
any suggestions?
Old 09-20-2011, 10:34 AM
Proprietoristicly Refined
John_AZ's Avatar
Very recent post to view:
No spark after timing belt change
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 09-20-2011, 11:23 AM
John_AZ's Avatar
Another post with serious discussion:
1 of many problems? maybe not
Continued:
DME Found missing grd no start
GL
John
Old 09-20-2011, 11:50 AM
