Driver
What should I do?
Car = '87 944na
I removed the adjustment screw from the bottom of my A/C compressor (I won't go into why). This is the part with the spherical bushing that screws into the adjustment strut for the alternator/AC belt. While screwing it back in I looked and noticed some metal shaving beneath the area I was working and I believe I may have cross threaded and started the process of stripping the threads on the hole. It is in there and feels fairly solid but I am afraid to take it out, and I don't want to screw it in any further. The AC isn't working but it isn't in the budget to get a new compressor. If I have bunged up the mounting hole at the bottom of the compressor, what can I do? GHEN
'87 944 |
I guess you might get a tap and die set and rethread the hole to a larger size.?
87 944 |
ASE Master
Helicoil
1989 944S2 (sold after 11 great years) 1980 911SC Weissach (bucket list car) 1975 914 1.8 (future restoration) 1993 968 Coupe 6 speed (new acquisition) |
one of gods prototypes
or just drill it out and use a nut/bolt through the whole thing, if you're changing the compressor later it won't really matter anyway......
Brought to you by Carl's Jr. |
Driver
I appreciate the input though...now to Google "helicoil" :-) GHEN
'87 944 |
the bolts at the end of the adjuster should come out, maybe it's just frozen in there? at least the 100+ i've seen come through the shop were.......
looks like this right? http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=944-126-021-03-M100&catalog_description=Adjustment%20Bar%20for%20Alter nator%20%26%20A%2FC%20Compressor%2C%20924S%2C%2094 4%2FS%2FS2%2FTurbo%2C%20968%2C%20Each
If you are so inclined to replace the entire alumium mounting bracket I have one that I am willing to sell pretty cheap as I will never use it.
Driver
Thanks, I'll look at it again. Of course I am afraid to back it out of the compressor without a "B" plan :-) Thanks, GHEN
'87 944 |
Driver
Unless I'm confused about what you are referring to? GHEN
'87 944 |
