Driver
What should I do?
Car = '87 944na
I removed the adjustment screw from the bottom of my A/C compressor (I won't go into why). This is the part with the spherical bushing that screws into the adjustment strut for the alternator/AC belt.
While screwing it back in I looked and noticed some metal shaving beneath the area I was working and I believe I may have cross threaded and started the process of stripping the threads on the hole.
It is in there and feels fairly solid but I am afraid to take it out, and I don't want to screw it in any further. The AC isn't working but it isn't in the budget to get a new compressor.
If I have bunged up the mounting hole at the bottom of the compressor, what can I do?
GHEN
'87 944
Old 07-16-2011, 03:39 PM
I guess you might get a tap and die set and rethread the hole to a larger size.?
Old 07-16-2011, 04:58 PM
ASE Master
alfadoc's Avatar
Helicoil
1989 944S2 (sold after 11 great years)
1980 911SC Weissach (bucket list car)
1975 914 1.8 (future restoration)
1993 968 Coupe 6 speed (new acquisition)
Old 07-17-2011, 08:54 AM
one of gods prototypes
bell's Avatar
or just drill it out and use a nut/bolt through the whole thing, if you're changing the compressor later it won't really matter anyway......
Brought to you by Carl's Jr.
Old 07-17-2011, 09:10 AM
Driver
I cannot use another nut/bolt. The bolt is permanently part of the bushing at the end of the adjuster, so there is no substitution possible.
I appreciate the input though...now to Google "helicoil" :-)
GHEN
'87 944
Old 07-17-2011, 10:12 AM
bell's Avatar
the bolts at the end of the adjuster should come out, maybe it's just frozen in there? at least the 100+ i've seen come through the shop were.......
looks like this right?
http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=944-126-021-03-M100&catalog_description=Adjustment%20Bar%20for%20Alter nator%20%26%20A%2FC%20Compressor%2C%20924S%2C%2094 4%2FS%2FS2%2FTurbo%2C%20968%2C%20Each
Old 07-17-2011, 04:17 PM
If you are so inclined to replace the entire alumium mounting bracket I have one that I am willing to sell pretty cheap as I will never use it.
Old 07-17-2011, 05:29 PM
Driver
Pelican Parts - Product Information: 944-126-021-03-M100
Weird, the spherical bushing rotates along with the bolt on mine. Does the ones you have seen press out? I don't see how it could unscrew out so maybe it is just frozen in there.
Thanks, I'll look at it again. Of course I am afraid to back it out of the compressor without a "B" plan :-)
Thanks,
GHEN
'87 944
Old 07-18-2011, 07:35 AM
Driver
Thank you, unfortunately the hole I am referring to is the one on the bottom of the compressor, and is part of the compressor body.
Unless I'm confused about what you are referring to?
GHEN
'87 944
Old 07-18-2011, 07:37 AM
