Rockin' NW Arkansas
firefighter7128's Avatar
Send a message via Yahoo to firefighter7128
Cruise control question
When i set my CC my car immediately jumps up 20mph. It will work ok on the freeway if i slow down to 55 so that it will jump up to freeway speeds. I would rather just fix this issue. ideas?
Matt
1986 Porsche 928 S - Daily Driver
1984 928 S - SOLD, 1986 944 S - SOLD, 1988 944 S - SOLD
Old 07-24-2011, 10:39 AM
tell me if i'm wrong but the cruise maybe goes every time on the same speed?
maybe the reset function doesn't work and it goes to last memory???
if jump every time for 20 miles then sens to be a problem in the brain,velocity calculation???
the easyer thing is to try another brain
if is not maybe something stucks the CC motor???
good luck
porsche 924 carrera gt 90% ready
porsche 944 NA 86' half 951
951 full project for 944
chrysler 300M
6 x 924 and 944 canibalized or death
Old 07-24-2011, 12:37 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
Try adjusting the CC cable. The CC tempomat is located in the right rear (passenger side) of the engine compartment. Remove the clip and pull the cable off the bellcrank, try and push the bellcrank back toward the fender. If the crank does move back toward the fender, then loosen the jam nuts and adjust the cable to the attachment ball on the bellcrank. Retighten the jam nuts.
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 07-24-2011, 02:17 PM
968 GUY's Avatar
Do a search. seems like someone just wrote up something on how to fix that. Involves opening up the controller that is under hood, throttle cable is hooked up to it, and cleaning some contacts. I need to look it up myself.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 07-30-2011, 11:12 AM
vdubr928's Avatar
Bad modulator unit. (Brain) sometimes can be reparied but they are redily available rebuilt for reasonable tax.
Not going to be cable if it is able to maintain that speed when it gets there.
82 928 s3&1/2 5 Speed LSD conversion
87 944 N/A 5 Speed (Under Construction)
81 931 (maybe for sale, well their all for sale lol)
Always looking for a good deal. Hello, my name is Carl and im a Poschaholic
Old 07-31-2011, 07:12 AM
