is there a way to lubricate the torsion bar assembly without disassembling?
or is there any lubrication needed on -81 924?
white 81 924
Old 09-16-2011, 01:14 PM
racer's Avatar
Why do you need to lube them? Its been my experience on 911s that you have to remove the torsion bar from the tube to properly lubricate it. Also, a great time to check if after 30 years its rusted or about to break. If similar to the 911, theres a good chance the big rubber bushing at the outside end needs replacement anyway.
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 09-16-2011, 01:27 PM
No you would have to remove them... But I really see no need to lube them. They are a stationary part. If they are moving, you have issues....
Old 09-16-2011, 03:20 PM
Exotic Vehicles are here
1-ev.com's Avatar
Porsche Crest
What about plastic bushings?
-Y.
"Y" <- My favorite question...
+ '68 911
+ Helping your business to get more business: http://myWWWapp.com
Old 01-17-2012, 11:58 AM
you need to remove the torque tube and change the bearings,job that is good to do every 20 years....
i did it on my 944 and 95% of all the noises go far far away!
porsche 924 carrera gt 90% ready
porsche 944 NA 86' half 951
951 full project for 944
chrysler 300M
6 x 924 and 944 canibalized or death
Old 01-17-2012, 10:19 PM
1-ev.com's Avatar
Hey Guys, sorry this is 924 thread...
I've posted it under 911 forums 911 Rear TB Bushings lube without removal
In quick: About 911 Rear TB Bushings, it might look like a wild ideas, but here that I was thinking to explore.
Thank you for your opinions.
-Youri
PS: I have NOT done this, just running through you, guys.
+ '68 911
Old 01-27-2012, 02:05 PM
9FF 9FF is offline
9FF's Avatar
There is never any need to lubricate anything in the torsion bar assembly as there are no metal bushings or bearings in there. The rear torsion bars on our cars act as springs and if you think about it would you ever lubricate your front springs?
There are a couple of large rubber bushes at the spring plate end and these do wear out...eventually. Just replace them if that is the case but you never have to lube them with anything. If you replace those rubber bushes with Bronze then that's a different story. You would have to then re-apply appropriate grease at regular intervals, say every engine oil change. The Bronze replacements have a fitting for this.
Old 01-28-2012, 04:38 AM
