Questions
Ok, i'm back on track! After being discouraged by gouged cylinders I got a really nice long block from joepfs. Thanks joepfs!! Yet another example of a porsche owner with class.
Now I'm starting the rebuild.
So onto my questions.
1) I'm trying to take off the drive pulley but because its on the engine stand the motor keeps turning. Any idea on how to stop the engine from turning so I can loosen the nut?
2) The pistons on my new motor are stamped with a number 1. I was told this is good to have. Is th there something to this?
3) I am going crazy? I've been bit bad by the porsche bug. I think about my porsche all the time. If I'm on the computer I'm on pelican looking for parts or looking at forums. I pop onto the internet at work in between projects to look at parts. I can't wait to work on it. Is this normal?
That's it for now. I'm sure I'll have more questions.
Thanks guys!
1985.5 Guards Red 944 N/A - current project but determined to be on the road again!!
Old 10-06-2011, 07:31 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
That is tightened to 155 ft/lb., so it's going to be a big effort to loosen it. I usually do it by holding a Flywheel bolt with a socket and long breaker (Often a two person job). Or if you have one an impact air wrench will work very well also.
That #1 on the pistons is to signify tolerance group 1. That's good because in case of bad break or extreme wear it's still possible to re-build to tolerance group 2 or 3.
Come over here and lay down on the couch so we can talk about your Porsche problem. You're lucky to get in here as there are hundreds in line for the same counseling. When was the first time you drove a 944 ??
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 10-06-2011, 08:09 PM
The first time I drove a 944?
Well .......... only just last summer even though I'd been in love with the 944 since 1986 when my english teacher bought a brand new guards red one.
The funny thing is, I haven't even driven my 944 once! It was being sold as a parts car but the only thing bad was the motor. I wasn't looking for a project car at all but I wasn't finding anything I liked that was running at a decent price and this was a great deal. Too good to pass up IMO.
So now I can't wait to get the motor rebuilt and back in the car and take it for a spin! It probably won't happen until next spring since I'm at the begining of the rebuild stage.
Of course, my brother asked if it was the mid life crisis car.
Old 10-10-2011, 05:39 PM
CatsEyes's Avatar
A pity the term mid-life crisis has come to cover anything new you pick up as a source of enjoyment in your middle years. Almost as if they should be dedicated to boredom!
I always thought the sign of a mid-life crisis was a bloke leaving his long-suffering wife of twenty years for a 25 year-old woman. Not the purchase of a 25 year-old car!
But hey, yes, in my family we all refer to the 944 as Dad's mid-life crisis car. Even me.
1980 911 SC Metallic Blue Euro spec, 'Greta'; 1986 944 Euro spec Light Bronze Metallic, 'Sabine II'
1986 944 NA Euro spec Guards Red 'Sabine I' - RIP, gone but not forgotten
'Hell is previous owners.' (anon.)
Old 10-10-2011, 08:43 PM
porschetub's Avatar
Something about these cars???
They have faults and you fix them,then when you drive them you forget all that,but if you get a bad one or someone like the PO has screwed up on servicing it will bite you bad,trust me.
While I remember I made a flywheel lock from an old aircooled VW starter pinion gear,worked great for getting the crank pulley nut undone.
Old 10-11-2011, 02:04 AM
Is the flywheel still on the crank(in the stand)? If so, just install a clutch bolt in one of it's holes, and use a medium length wrench jammed between that bolt and one of the arms on the engine stand.
If not, install two of the flywheel bolts in the crank and bind a breaker bar between those two bolts and allow it to "counter" against said engine stand.
Good luck, and keep us updated. Inspect everything very well in the area of the crank' like rod-bearing journals, rods, and crankshaft thrust.
Any questions, just post them up here.
Old 10-11-2011, 06:53 AM
Back from Beyond
You are SO not alone in your obsession...
Here's some entertaining reading for you: http://www.924board.org/viewtopic.php?t=32075&highlight=
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 10-11-2011, 08:16 AM
