Novice
Rear hatch noise
I have a creeking sound coming from the rear hatch (or at least I believe the read hatch). The gasket is in great shape. The only thing I can think of is the 2 pins. Can I adjust the pins so the hatch does not close so tightly, but still engages the lock and keeps water out?
Any help is appreciated.
Old 10-26-2011, 06:04 AM
I'm sure your hatch has what we all call as delamination or seperation of the top of the glass from the frame. That sucks. My car has it, and I resealed it with window weld it held for 6 months then pop it did it again. Sucks.
Old 10-26-2011, 07:12 AM
That is my idea to fix the issue without having to tear down the entire hatch. Basically attach the trim piece with window weld so that the glass is held in place. Not sure if that will help or not. Need to make sure that your frame isn't bent.
Old 10-26-2011, 07:26 AM
porschetub's Avatar
Not always
The rubbers in the latch pin retainers wear out and the latch pins move in the retainers,too many people say the hatch frames come loose from the glass,not always.
Are your latch pins adjusted right? remembering that everything settles down after awhile.
They generally leak when the frame has come away.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 10-27-2011, 02:01 AM
Got boost?
derekc23's Avatar
My hatch wouldn't open so I pulled the bottom retainers off and found the remains of the original rubber (looked more like greasy goo).
Is there any easy fix for replacing the rubber in the latch pin retainers?
1986 951, 89k miles, CCW Classics (black) 17" x 10" (275/40) & 17" x 9" (255/40)
Old 10-29-2011, 02:31 PM
