Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Help with taking apart a caliper
Hi all,
Right now I am taking apart some calipers I picked up at a Pick-n-pull lot. They're from a Porwche 944 (1984). Right now I have the pads out and the only thing holding the two halves together is the spring clip (part #6 on the exploding diagram). When I try and pull the ends out with a pair of needle nose pliers they don't seem to want to ome out. Is there any special way to do that?
Also, any good suggestions on where to buy replacement pistons IF I end up needing them?
Thanks for any help you care to give!!
Robert
Old 10-27-2011, 11:03 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Non Compos Mentis
If you need pistons, buy them right here at Pelican!
I recently rebilt the rear calipers on my 944S. The spring clip doesn't hold the halves together- They are a tight fit, but they can simply be pried/banged/slid apart. Mine were a bit difficult, as they hadn't been apart on who knows how many years, but after some frustration, a naughty word or two and a bit of redneck ingenuity, I got them apart.
DO put them back together correctly the first time, or you get to do it again. Don't ask....
If you take one apart at a time, the other one is still complete to help remember how the pieces go back together.
Life is short. Drive fast.
Old 10-27-2011, 12:03 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Toofah King Bad
Rasta Monsta's Avatar
If you disassemble all four at once, write down casting numbers on the caliper halves and the pots.
» 1980 931 - Got boost? ♦ 1987 924S - Pro44 ♦ 1987 924S - Junkyard score «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 10-27-2011, 12:44 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Misunderstood User
Caliper rebuilt is easy. I bought everything I needed on Pelican: Pads, clips, rebuild kit, etc.
Go invest in a Motive Bleeder and it will make putting brake fluid in easy.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 10-27-2011, 01:29 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
Thanks all!! Definitely doing them one at a time as this is my maiden voyage working on brakes. Will be a little more forceful when I go back to them. Guess I was just worried about busting something.
Robert
Old 10-27-2011, 01:59 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
Tags
caliper, caliper hardware, calipers
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
