Cv axle problem
I recently put a new cv axle on my 88 944. Well a couple of weeks ago I put it to the floor and one them broke. Well, sent it back as a default part and the put the new one on. Well, I was driving it again today and the other side broke when I put it to the floor. Only thing I can think is that there is too much torque in the wheels for it. Idk. Any help?
Old 10-27-2011, 04:52 PM
yarfk
kfray's Avatar
Are you popping the clutch and spinning the wheels ?
------Keith------kfray------yarfk-------
87 944 NA stock 116k
06 Honda Ridgeline 83k
10 Vibe 2.4 AWD (Wife's)
Retired My week consist of Saturdays and Sundays
Old 10-27-2011, 05:37 PM
It usually happens when I shift into second. And yea the wheels are spinning at the top of first
Old 10-27-2011, 05:49 PM
Proprietoristicly Refined
John_AZ's Avatar
Are these OEM Porsche quality?
What is breaking? Are the bolts OK?
Ideola's Garage: Stage8 Fasteners for Porsches
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 10-27-2011, 05:51 PM
9FF 9FF is offline
9FF's Avatar
John
I am presuming that the cv joints are failing and am guessing they are not EMPI/GKN/Lobro type-2 joints.
Did you replace the joints yourself or did you buy complete half-shafts from autozone, napa, etc?
If you replaced them yourself did you get the good quality joints mentioned above or some inferior cheaper ones?
Did you ensure the cages didn't miss-align when you fitted them?
If you bought rebuilt complete shafts with the lifetime warranty from autozone, etc., chances are they use the cheaper joints and are prone to failure.
If it is actually the bolts that are failing, chances are you didn't clean the threads out or didn't torque them correctly.
If you buy the good quality joints, take care to align the cages and level the shafts before torquing them to the factory torque, and clean the threads out properly before fitting the bolts, this will not happen.
Old 10-27-2011, 06:07 PM
Watchu talkin' 'bout Willis?
Seriously, what do you mean by aligning the cages? Level the shafts?
Old 10-28-2011, 09:47 AM
9FF 9FF is offline
9FF's Avatar
Quote de 9FF
For people doing the job on jack stands. They usually let the wheels hang which causes the axles to angle downwards towards the wheel hub. If you try and tighten the bolts that way the cages can misalign when the wheels get put back on the ground.
Some good info on cv joints and axles in this thread: http://forums.rennlist.com/rennforums/924-931-944-951-968-forum/660850-dont-buy-autozone-cv-joints.html
Post about missalignment of cv cage: http://forums.rennlist.com/rennforums/8268417-post24.html
Old 10-28-2011, 09:58 AM
For people doing the job on jack stands. They usually let the wheels hang which causes the axles to angle downwards towards the wheel hub. If you try and tighten the bolts that way the cages can misalign when the wheels get put on the ground.
I just did both of my axles on jack stands. How would I check to see if my cages are misaligned?
Old 10-28-2011, 10:13 AM
9FF 9FF is offline
9FF's Avatar
If you are not getting any noise or adverse effects, vibration, etc, they are fine, it only happens occasionally, it could even be a fault of the cheaper cv joints with thinner cages, but just saying it can happen if you fit the axles that way. I have seen someone fit the axles like this, have grinding issues and found a cage completely distroyed when he replaced it a second time. He leveled the wheels on his second attempt and all went well.
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 10-28-2011, 10:20 AM
Thx!
Old 10-28-2011, 10:31 AM
Banned
Some good info on cv joints and axles in this thread: Don't buy Autozone CV Joints - Rennlist Discussion Forums
Post about missalignment of cv cage: Rennlist Discussion Forums - View Single Post - XP: Rear end noise out of ideas. SOLVED
is an acceptable solution to jack the car up, and then puth the wheels on blocks to tighten the shafts?
Old 10-28-2011, 10:44 AM
9FF 9FF is offline
9FF's Avatar
That's how I'd do it if I didn't have access to ramps or a lift. Jack car up and lower wheels onto blocks to keep the shafts level-ish and the car still raised enough for access.
Old 10-28-2011, 10:52 AM
Oh man...What now?
iplagolf's Avatar
9FF, Every once in a while I fall into doing something right by accident. When I did my CV's I used my new ramps and used a floor jack to lift the tire off of the ramp to spin the tire/CV joint. Fritz
Me and Porsche's go together like cocaine and waffles. Those don't go together. Well, peanut butter and women. Don't you mean jelly? You put jelly on women? (Ricky Bobby, Talladega Nights) 1985.5 944 Alpine white
Old 10-28-2011, 03:18 PM
