Replace ignition with Starter button.
Anyone have steps or schematics on changing ignition to a starter button ?
thanks!
Old 11-10-2011, 10:36 AM
You will need to cover the 0, 15, 30, and 50 tracks.
Old 11-10-2011, 11:04 AM
winter-hater club member
nynor's Avatar
tlechner, i am pretty sure its been done. do a search.
"COOL PRIUS!" - Nobody Ever
Old 11-10-2011, 11:06 AM
NY944Turbo
minho78's Avatar
DIY Push Button Start / How to hotwire a 944 - Rennlist Discussion Forums
Old 11-10-2011, 11:10 AM
1984 porsche 944 na
ballysdad's Avatar
1 switch on/off, 1 switch positive, neg, load both at pep boys $6 each or less. 12guage wire,blade connectors, 1 30amp inline fuse. Push 2 wires through gromet on firewall behind brake booster. I used a coat hanger came out under dash taped wires to coat hanger and pulled through to engine compartment. Ran those 2 wires under center console to where the switches on console are. I dont use rear wiper switch and had a blank in another. Filed switch holes to fit each switch. Connect positive wire from battery to on/off switch one side,other side goes to positve of next switch. Grounded 2nd switch through center console to fuse panel ground and connected 2nd wire that goes through firewall to the load connector on switch (to starter solenoid) Now the 2 switches are wired on/off switch is safety for the other switch sends power to start switch when turned on. In engine compartment Positive wire to inline 30 amp fuse to positive battery terminal. The last wire route to starter solenoid and put on where ignition wire goes. I removed the origional ignition wire and taped the end. To start car:
Put key in ignition turn 2 clicks. Depress switch 1 to on. Depress switch 2 stater will engage then switch off when car is started. When car is started depress switch 1 to off so you dont hit starter button by accident while driving.
Less than $20 worth of material if you have nothing and works great..
As for the switches need one with 2 prongs and 1 with 3 prongs. 2 prong switch is safety switch, 3 prong plug has postive/negative/load
1984 Red NA/Sold
1984 Gray NA/Sold
1986 Red NA
1986 Gray NA
Old 11-10-2011, 11:33 AM
Comeau Racing
...or you can buy the starter switch panel from Longacre, which comes with instructions. I have the one with main power, push to start, plus two aux switches for camera and cool suit.
PCA since 1985
77 924 MARTINI Edition rescued,SOLD
88 924S Special Edition rescued,SOLD
Comeau Racing Enterprises, Inc. www.comeauracing.com
We do only 924S, 944's, 968's all day, every day.
Old 11-12-2011, 09:28 AM
thanks heaps everyone !
Old 11-14-2011, 10:45 AM
