What is my Offset?
I have a '86 944 na. Is this the early or late offset? What is my offset Front and Rear?
Thanks, Mark '85 928S Euro, '86 944, '91 525i, '95 840ci '96 328i, '97 328i, '99 528iT, '85 635csi |
Non Compos Mentis
Last year of early offset 944s. 23mm.
Garage Helper
+1^ The early off-set is 23mm front and 12mm rear. The differences you will find when replacing the early off-set rims with late off-set rims is the use of 21mm to 25mm Wheel adapters. Front struts, A-arms, and Tie Rods are also different between early and late off-set.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word |
