LinkBack Thread Tools Rating: Thread Rating: 6 votes, 3.67 average.
sushiman007's Avatar
Back running again, 3 months after the flood:)
Today, I replaced some of the 30-year-old, cracked, stock vacuum hoses w/ones from Lindsey Racing, and reinstalled the reconditioned air flow meter and my '84 N/A fired right up for the first time in 3 months after it stalled in a July flood!
Not only did she rev strongly and accelerate smoothly (just like a 944 w/a rebuilt engine should); the high-pitched noise associated w switching on the A/C, which I originally thought was a belt, or a roller issue, also disappeared.
I want to thank you all for giving me many great advice and encouragement to keep me from giving up. Now, I can get back to driving and enjoying this wonderful creation from the Big 80's!
Old 10-05-2014, 06:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2601 (permalink)
EliteThink's Avatar
coolant system emptied after the plug broke. 7 days out at the dealer, I called all the Porsche shops and Redmond European pulled one out of their inventory. Refilled, spent the next 2 days making sure it was bled. Running okay for now.
Old 10-05-2014, 07:59 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2602 (permalink)
PetrosS2's Avatar
in the paint shop
https://plus.google.com/116615986427952997378/posts/H3bgHsSbWiB?pid=6067138412863478482&oid=116615986427952997378
Old 10-06-2014, 09:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2603 (permalink)
Put the finishing touches on what started as a tie rod job (and ended up as 1.5 months of the car not running) and got an alignment done. I now have a front-right tire hum (I probably overtightened the wheel bearings), a sticky starter that will need to be rebuilt before I start the car again, and the assertion from the alignment shock that they can't get my front left camber/caster in spec because I need a new front left "shock" (I assume insert. This comes as no surprise; I've been thinking the front left shock looked a bit lower than the right for awhile.)
The fun never ends...
1987 Guards Red 924S
1986 White Toyota MR2
Old 10-06-2014, 11:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2604 (permalink)
Dropped it off to have the front of the motor redone. Belts, pulleys, pump. The whole she-bang.
Have the brake fluid and coolant flushed while its in.
Good for anther 30K, WooHoo!
David #476
'78 911SC (gone home to the Fatherland)
'92 968 CAB
Beck Spyder #201
Too many bikes to list
Old 10-06-2014, 12:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2605 (permalink)
Patrick
pfarah's Avatar
Raised the front up and measured clutch wear: 24.6mm. Looks like I'm good for a while still. Since she was up in the air, I installed a recently purchased aluminum belly pan with the TSB modification already performed (one inverted vent).
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 10-06-2014, 04:24 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2606 (permalink)
Pulled starter with the intention of cleaning the solenoid and lubricating the bendix. Solenoid screws are all sorts of stuck, so it's getting the PB blaster & hammer treatment. I'm guessing it's the original starter/solenoid.
Old 10-07-2014, 04:29 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2607 (permalink)
jwmc1's Avatar
New Blaupunkt Speakers
John
Old 10-12-2014, 06:39 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2608 (permalink)
I installed my IMI starter. I like it.
Currently have: Guards Red 1987 924S 16v -- Light Blue Metallic 1980 928
Gone: Minerva Blue 1979 928 -- Gray 1985.5 944 -- Black 1989 944 -- Black 1984 944 -- Black 1987 944S -- Alaska Blue 1974 914 1.8 -- Guards Red 1983 944 -- Guards Red 1987 924S -- White 1988 924S -- Maraschino Red 1987 944 Turbo -- Beige 1981 924 -- Red 1984 944
Old 10-12-2014, 08:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2609 (permalink)
Andrew Gawers' Dad
CHICKS's Avatar
Last few days: Only944's inner/on body sunroof seal, and did what the TSB said for the airbox/belt cover vent. Parts were $12 from the dealer.
Old 10-13-2014, 06:27 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2610 (permalink)
PetrosS2's Avatar
Old 10-14-2014, 10:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2611 (permalink)
One apex at a time
Dean924s's Avatar
Not today but last week I finally got the cracked windshield replaced.
Respectfully
Dean
General Car Specs & Mods
Project Megasquirt 924s
Old 10-14-2014, 01:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2612 (permalink)
PPI came out clean.
Old 10-14-2014, 03:05 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2613 (permalink)
Chunkerz's Avatar
Today I unboxed my Power Flex front/rear swaybar and torsion bar housing bushings.
Then I reassembled most of the rear torsion bar housing.
Last thing I did was install the two big bushings on my new 26.8mm front swaybar.
I put on tons of the included copper grease, so hopefully they won't squeak like people say they do.
Old 10-17-2014, 06:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2614 (permalink)
curtisr
curtisr's Avatar
Found some time today to replace the driver's side window regulator. Sadly, when I opened the box containing what was described as a 'very good' condition used-part, I discovered that the point of contact between the motor and the regulator was broken and, in fact, missing chunks of metal. Luckily the motor worked so it was a quick substitution and all was well. And while the ultimate cost to me was not all that much I must say it was a clear case of caveat emptor.
1977 924 Guards Red (parted and sold)
1987 924s Alpine White (sold)
1987 924s Kopenhagen Blue (my Lowencash tribute track car -- sold)
1987 924s Garnet Red (currently becoming Lowencash II)
1982 928 Silver (sold)
Old 10-19-2014, 02:16 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2615 (permalink)
I checked my selling history on eBay because I sold a very nice one recently, and whew, mine went to Australia.
Old 10-19-2014, 03:22 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2616 (permalink)
winter-hater club member
nynor's Avatar
i re-tensioned the timing belt. the balance shaft belt was spot on. i'll revisit both in about six months.
"COOL PRIUS!" - Nobody Ever
Old 10-19-2014, 05:50 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2617 (permalink)
Chunkerz's Avatar
Today I touched up some of the undercoating, fixed my unmovable spring plates, installed the torsion bar housing, and bolted up my control arms. I can finally see light at the end of the tunnel....
Old 10-19-2014, 08:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2618 (permalink)
PetrosS2's Avatar
https://plus.google.com/u/0/+PetrosPeter/posts/Cqnm5sfJ3qC?pid=6072257617699979938&oid=116615986427952997378
Old 10-21-2014, 10:33 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2619 (permalink)
p-talk's Avatar
@Chunkerz: You appear to have your rear coilovers on upside down. Not sure how much difference it actually makes, but thought you should know.
1984 Porsche 944 - Mathilda the needy
2014 Audi Allroad - daily driver
Old 10-21-2014, 10:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2620 (permalink)
